2006 Prius Advice
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Josh Imholte, Jan 24, 2018.
  1. SpaceCityHybrids
    38
    52
    Houston
    I am working on providing that service soon. The dealer cost is excessive.
    Raytheeagle, SFO and Prodigyplace like this.
  2. SpaceCityHybrids
    38
    52
    Houston
    I have already encountered 2 that have this issue in my area without any prior brake fluid change. One vehicle is one of my own, the other a coworker. You can expect these numbers to rise.
  3. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Since neither of these failed from changing the fluid, would you advice against this preventative maintenance practice?
    Is there a TSB for gen2 that details this?
    Raytheeagle likes this.
  4. JC91006
    16,931
    8,640
    Going off my recollection, I've read that Toyota had advise dealers AGAINST brake fluid flushes on the gen2 cars. Because the bleeding procedure would contribute to the failure of the actuator. But unfortunately, I cannot find any TSB that is stating that (I'm not that good with research).
  5. SpaceCityHybrids
    38
    52
    Houston
    I haven't seen the TSB that advises against changing the fluid. But unless your fluid is low or very dirty, I wouldn't flush it. If it is dirty, flush it. The risk of dirty fluid causing harm is greater than not having it done.
  6. SpaceCityHybrids
    38
    52
    Houston
    Contemptible if true. That advice is along the same line of advice of people not changing their transmission fluid to prevent failure, when in reality if it causes an issue the transmission was already failing.
  7. 06 Amateur
    06 Amateur Junior Member
    Northeast Ohio
    Sorry to bump an old thread, but I couldn't figure out how to private message Josh Imholte. I'm hoping he might get a notification of my reply here and come back to answer.
    I would be interested in knowing how the Cardone battery worked out for Josh. Is it still going strong three years later? Or were there problems with it?
  8. JC91006
    16,931
    8,640
    Don't buy a used battery when you can get a new one for $1695
    Prodigyplace and Raytheeagle like this.
  9. Prodigyplace
    12,710
    11,847
    Central Virginia
    Unless you get a low mileage junkyard one, NEVER buy a used battery. Long warranties to not mean reliability, unfortunately. If you DIY you can get a kit of new cellh foe $1600 delivered and can sell any of your good old modules to lower the price further.The newpriusbatteries link is in my signature. IMO @2k1Toaster here has done an awesome job with this good as new option.
  10. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    It my shop, I had one week when I came across three Dorman batteries that had failed before they were a year old. Not answer to your question, but maybe that will help you.
    Prodigyplace likes this.
  11. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Avi,
    When Dave Taylor was selling his ReInVolt batteries, they proved to be reliable and long lasting (I had one installed in my 2004 Prius). After he sold the process to Dorman, their attention to detail proved lacking and the quality suffered.
  12. Avi's Advanced Automotive
    776
    363
    I'm not sure that's the issue. Back when Dave Taylor sold it, wrecking yards were overflowing with fresh batteries full of healthy modules.
    Today, the pool of modules is filled with old, worn out modules. Mixing and matching them is a waste of time. I think it's just that the situation has changed.
    dolj, Prodigyplace and JC91006 like this.
  13. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    Dare I even speculate that Dave could see the writing on the wall and took the opportunity to cash up while his business still had value.
