2006 prius ATF
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by notyvp, Nov 29, 2016.
Tags:
  1. notyvp
    notyvp Junior Member
    St 454 #67eo
    Hi all
    I just buy 2006 prius and change ATF
    I use this product MITASU_32_ENG.pdf.
    it is right product?
    thanks in advance
    Sovannoty
  2. b100
    b100 Member
    145
    75
    Netherlands
    It says by Specifications ATF WS so i would be compatible.
    But.. the most people use the genuine from Toyota.
    And then you know its right. So if i would be you, i change it to the orginal toyota atf ws.
    Because this oil has only the atf ws specification and no other specs.
    notyvp likes this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Notyvp-
    That should work fine. 100% synthetic. Lots of people use all kinds of atf including Wal marts brand. I use Redline D6 and works excellent.
    notyvp likes this.
