2006 Prius Buzzing/Grinding Sound When Turning
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Frank Kasell, Apr 22, 2016.
  1. Frank Kasell
    Frank Kasell Junior Member
    Hello, potential trouble-shooters. In the past few days, our car (2006 Prius) has begun making some louder-than-normal noises while driving. I've determined that the noise appears when you turn the wheel at all to the right (note: not just making a right turn...any degree to the right past straight is enough). It seems to be constant when the car is running, but really only becomes perceptible around 30 mph. The sound is sort of like a buzzing. Maybe a grinding, but not quite. It sounds like it might be similar to this issue (2006 Engine Noise - buzzing, especially loud on highway | PriusChat), but I can't quite be sure.
    Any ideas what's happening?
  2. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    Two of those resolutions were wheel bearings, which is my initial suspicion.
  3. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Wheel bearings get louder with speed and are always making noise, the steering wrack on the other hand makes noise when used, no mention of miles, my 06' whell bearings went at 40,000 and the steering wrack at 60,000, I'd get it looked at.
    52,694
    constant velocity joints? how many miles on her?
  5. Frank Kasell
    It's around 139,000 miles right now. We got it used, so I don't know for sure, but I don't believe the wheel bearings have gone out before this.
