2006 Prius clock spring (spiral cable) repair
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mswtoyota, Dec 19, 2014.
  1. AvTech72
    AvTech72 Junior Member
    32
    Miami Beach, FL 33140
    Three Touring
  2. vaughnstark777
    191
    33
    Roy, WA
    2001 Prius
    I
  3. AvTech72
    32
    Three Touring
  4. vaughnstark777
    191
    33
    Roy, WA
    2001 Prius
    I
    The one I shared is les than $9 and I have purchased and installed one on my 2004 and everything works, no one issues. I bought two, just in case, and I have a 2007.
    I took the gamble and it paid handsomely.
  5. AvTech72
    32
    Three Touring
    How long ago did you install it?
    And do you have a reference of how to access it by taking off the airbag and anything else thats in the way?
  6. vaughnstark777
    191
    33
    Roy, WA
    2001 Prius
    I
    Last week and university of YouTube:
    Samuel Williams Jr likes this.
  7. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    No
    iPhone ?
  8. AvTech72
    32
    Three Touring
    Did it as well, thanks for sharing!!
    Mine does work well, all the cruise control and dehumidifier buttons have come back to life.
    Even if it only lasts a year.. $10 a year for who knows how many years I'll keep the car,most likely 5+. vs. $220 OEM, at this rate i have 22 years before I equal the cost. oh yea and 30min of labor TOPS with that video.
    One thing I will add, is that you need to transfer one small sensor bracket when you take of the spiral spring assy, relatively easy to do, just a few tabs on both sides and your good to go.
    Last thing is to make sure your steering wheel is centered with the arrow on the spring assy pointing down and in the window the orange window is showing to confirm you are centered.
    When I did disconect the battery as shown and reconnected the battery at the end, the panel did show me the 2nd row of orange indicators all stayed lit and did not let me change out of park(only to neutral). But after letting it rest maybe 10mins, when I turned the car back on, it passed the self test and was back to normal.
    Good luck gentleman!
  9. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    You don't need to wait 10 min, when you get the dash lights up showing they are all working, you can just press the power button a second time (with your foot on the brake) to go to READY.
    FYI, you can get the OEM part for more like $160 by shopping around the online Toyota stores.
    Personally, I would only want to do this once and forget it. My labor is worth $75 per hour to me so that is only 3.4 years to break even and I'd gladly pay that premium to not have to do it again. However if you're happy to do this annually, more power to you.
  10. AvTech72
    32
    Three Touring
    I maybe didn't search thoroughly enough but yes 160 sounds a bit more reasonable to buy one time and forget about it.
    And I DID go to ready with all the amber dash lights showing on. That's why I said I had to turn off,wait,and turn back on to give the system time to fully come on and pass the self test.
  11. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    Some folks have a lot of free time It looks like so when you have a lot of that and you're really thrifty I never use the steering wheel buttons every time you push the stupid thing everything goes into auto mode and blows on high and makes it ridiculous racket and oh God never use it almost never put the heat on even if it's 32° or below outside here in the south and the air conditioner always has to be on low no temperature setting and the fan where I want it and the yellow light over the air conditioning button and that's pretty much it and I turn that stuff off before I turn the car off as I'm pulling into the parking space or driveway I never turn the vehicle off with all that crap running full tilt Just seems to me to not make sense but everybody I ride with in their car is the exact opposite they just turn the key off or push the button with everything radio air conditioning clutch engaged on the air conditioner all of it click off not myself I just don't treat things like that and of course all four of mine are working like they've always been supposed to I've had to replace one clock spring and it took 28 minutes and it came off of an '05 car sitting right next to me in my driveway so cost was like nothing that car still running and driving It's my work vehicle I drive it daily.
  12. AvTech72
    32
    Three Touring
    Did i buy the wrong part? On the left is the oem part from toyota, right is my malfunctioning ebay version installed over 5 years ago. There is a 3rd female connector port missing for the new oem assy
  13. Tombukt2
    13,875
    2,521
    Durham NC
    Does the white thing not unplug from the main part of the spiral cable assy block set it turns to black . Will. It disconnect at that point is this the diff between 05 and 06 up? I don't have them off to look at at the moment
