2006 Prius Died on Freeway
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bandittraps, Jun 19, 2018.
  1. bandittraps
    bandittraps New Member
    Arizona
    Hey everyone. Just to preface this, I am NOT a car guy at all, and I'm sorry if this had been posted before. I scrolled through and read some of the threads, but none of them seemed to match with me exactly so I thought I'd post myself.
    Last week, my 2006 Prius with 190,000 miles dash just went black while going 65 on the freeway. It lost power and I had to coax it off to the side of the road. No warning lights came on and there were no sounds, but I thought I might've smelled a slight electrical burning right before the dash went black, but when we lifted the hood I couldn't ssmell anything anymore. I called some friends and we tried to troubleshoot it for two hours without success before having to tow it back to my house.
    When we were troubleshooting, we noticed the gas was low and so was the oil. I had planned on getting an oil change over the weekend for the car, so didn't think it was a big deal. I'm hoping the engine didn't seize up but maybe it did and I'm a complete idiot. Other than gas and oil, we tried to jump the car but that didn't work and the car literally won't start. So possibly the battery is donezo? We also checked the fuzes but they all seemed fine. The headlights were still working at that point and so were the hazard lights, but now they won't come on and it's been a week.
    So my question is: Does anyone know what's wrong? What would be the best, cheapest way to troubleshoot what happened? I don't have the money to tow it to a dealership at all.
  2. Patrick Wong
    18,214
    6,530
    1. Measure the voltage of the 12V battery. A new, fully-charged battery will measure 13.0V. A discharged battery will measure 12.0V. Your battery is probably way below 12.0V if the lights do not even work. Put a charger on the battery at least overnight. If the battery cannot be recharged, replace it.
    2. Check the 15A AM2 fuse. If it failed, the root cause most likely is a failed inverter coolant pump which is located behind the driver's headlight assembly. Disconnect the wiring harness connector to the pump and see if the car will run with a new AM2 fuse.
    3. Check the 100A DC/DC fusible link which is located within the 5" long white/clear plastic box within the main relay/fuse box next to the inverter. If it is blown, then you reversed polarity during the jumpstart process. In that case, look for other blown fuses and you may have damaged the DC/DC converter within the inverter which will require you to replace the inverter.
    4. Check the 120A MAIN fuse which is located within the 12V battery positive terminal connector (under the red plastic cover).
    SFO and JC91006 like this.
    52,891
    ^^^THIS SHOULD BE A STICKY^^^
  4. JC91006
    16,939
    8,647
    This should be reported to the national highway traffic safety administration
    SFO likes this.
