2006 Prius Engine Replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KitsuneVoss, Jun 24, 2025.
  1. KitsuneVoss
    KitsuneVoss Member
    375
    55
    Virginia
    Are you say that I can just pry them apart and then try to remove the bolt from the transmission?
  2. Tombukt2
    Tombukt2 Senior Member
    13,677
    2,478
    Durham NC
    I'm actually not certain what bolts you've broken off by the pictures provided but . The head braking off the trans should pull away the bolt head is gone that's what holds .
  3. KitsuneVoss
    KitsuneVoss Member
    375
    55
    Virginia
    Took three pictures to see if I could show you
    The other three bolts do not have threading to the end but this one looks like it does but could be mistaken and something could have happened in the twisting that makes it look that way. Are all 4 14 mm bolts the same? If so, I should be able to just slide this one out and then work on removing the bolt from the transmission.
  4. KitsuneVoss
    KitsuneVoss Member
    375
    55
    Virginia
    Day Nine:
    No pictures but removed bolts holding the exhaust manifold on the engine. 12 mm and 14 mm.
    Question, other than that bolt, are there any bolts holding something like a flywheel or will the engine simply slide out of the transmission? Videos I have seen don't show anything like that but other cars have bolts holding a torque converter on the engine.
