2006 Prius... help me fix
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KadeH, Dec 2, 2015.
  1. KadeH
    KadeH New Member
    Alabama
    I have a 2006 Priusit has about 300k miles on it and doesn't run the obd said P0AFA Hybrid Battery System Voltage Low...I really need someone expirienced to help me out. Have owned for a few days and I don't think so...I'm not educated with the hybrids and how they work so try and keep it simple thanks
  2. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    I am not a battery expert, but you first want to make sure you have a good charged-up small 12volt battery in the rear compartment. A run-down 12-volt battery could explain why you cannot start and maybe be the whole issue (if you're having a good day). If you're having a bad day, you may need a new hybrid battery.
  3. KadeH
    KadeH New Member
    Alabama
    So just break out the battery charger and find the back compartment and try charging it up
  4. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    You can try that but what you really need to know and what people who are willing to help you need to know is the condition of the 12 volt battery first as a failing or failed 12 volt battery can create several DTCs.
  5. bisco
    52,904
    if you don't know much about cars, a 10 year old car with 300k is probably not your best choice.i don't know much either, but it sounds like your hybrid battery needs charging, which requires a special charger. all the best!(y)
  6. KadeH
    KadeH New Member
    Alabama
    How would I know or figure out if it's failing? And could you link me to a replacement battery?I bought this car to repair and sell. I got it for extremely cheap and has little cosmetic wear it was well kept. Just need it running.
  7. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    If you can get the car running (with a fresh 12v) you can charge up the HV batt on a Gen2 by revving the engine with your foot on the brake. Otherwise there is equipment from Toyota that can charge up the HV batt, assuming that is discharged. But the concern would be the HV battery is damaged due to being discharged,6
  8. bisco
    52,904
    if you can start the engine to charge the hybrid battery, you don't need to charge the battery.:pyou are going to repair it, but don't know how to tell if the12 volt battery is failing?
  9. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    one way to find out if the 12v is failing is to take it out of the car and get it tested at the parts store. you can look for a date code on the battery to determine if it is original-- in which case its probably weak or dead. you can try to charge it if you have a charger, but really, you got a good deal on a prius with 300k? HV battery is probably toast and that's why you got it cheap.
    still, you got to have a good 12v hooked up to the car before you can even start to find out if or what else is wrong with it. if you have a known good 12v, hook it up across the one in the car and see if that helps.
  10. KadeH
    KadeH New Member
    Alabama
    1000$ for car $1000 for new battery and sell for 3grand maybe 3500 and 12v is fine ignition turns on and there are lights on the dash and everything but it just won't try and turn
  11. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Did you at least disconnect 12v you will reset the codes/computer reboot and give it another shot.
  12. bisco
    52,904
    is the 'ready' light coming on?
  13. 69shovlhed
    2,170
    752
    Delaware
    12v is fine? how many volts does it have with the car off? and then how many when its on? dash lights only mean its not completely dead. I did have one come in on a hook. it had dash lights but wouldn't go ready. i charged the 12v battery and cleared the codes and it started and ran, so I drove it out, but several codes indicating the HV battery was bad came right back.
  14. KadeH
    KadeH New Member
    Alabama
    How would I go about "disconnecting the 12 volt" is it as simple as it sounds or????
  15. KadeH
    KadeH New Member
    Alabama
    I don't think so I don't see a ready light anywhere
  16. KadeH
    KadeH New Member
    Alabama
    Get on my OBD and erase all codes and restart it and see if it will run?
  17. JC91006
    16,939
    8,647
    $3000 for a car with 300k miles......sounds like you should just flip it with the problems for $1500 and call it a day.
    Blu-ray likes this.
  18. KadeH
    KadeH New Member
    Alabama
    Running I should atleast get 2000
  19. JC91006
    16,939
    8,647
    you obviously don't know much about cars, let alone a complicated Prius. You might even end up losing money if you keep this car.
    Mendel Leisk and Blu-ray like this.
  20. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Just take off the negative lead screw where the wire connects to the chasis in the back.
    You have to depress the brake pedal when then power button is pressed to get READY. Wait a while and engine will start, or step on gas.
