2006 Prius Hybrid total electrical failure
Discussion in 'Gen 2 Prius Main Forum' started by tmulcahy, Jul 27, 2017.
  1. tmulcahy
    tmulcahy Junior Member
    Albuquerque
    Hi. I lost my perfectly running 2005 Prius Hybrid about six months ago when a driver turned a corner sharply into my front end while I was at a stop sign. Ran perfectly, but when I tried to fix the front end, the insurance company considered it a total loss, because the crumple zone was, well, crumpled. Very expensive labor to replace that whole section of frame. Sad.
    Anyway, I took their check to a dealer and picked up a 2006 model for a little bit more than the check amount. It's been running fine, but just now, an alarm came on, and when I went out and got in, I turned the engine on because the unusual alarm wouldn't shut off. All seemed fine. (In fact, I had driven it today, and shortly before this happened, had gone out to the car to retrieve a CD from the player. Engine started right up, and CD player was fine. Removed the CD, and replaced it. Shut the motor off.)
    So now, there is no power at all. Neither key fob nor button will unlock the doors. I have to use the key. However, even when I get in, I cannot use the unlock control in the door to unlock all doors. I can't even get to the 12v battery, because I can't get in the back. I will have to pull the seats down, and crawl back there, but I still don't know how to open that hatch. Is there anyone who can give me any advice? This is bizarre. Never had a problem like this with the 2005. No engine, no electrical, no power of any kind. Help!
    52,776
    there's a cover over the manual release back there. i forget exactly where, it should be in the manual.
    you can also put a 12v source on the jump point under the hood.
    the battery probably went dead sitting on the dealer lot.
  3. strawbrad
    953
    1,007
    Check the 15 amp AM2 fuse. A failed shorted invertor coolant pump will cause this fuse to blow. With a blown AM2 fuse about all that works is the dome light.
    Brad
    fotomoto likes this.
  4. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    Yes, your best bet is pop hood and look in the top right corner area for black fuse box...open it and you'll see a red piece of metal that you attach positive to...it is tiny and hard to clamp onto... some jumper cables will be too big..
    If car operates normal after jump u just need battery.
  5. strawbrad
    953
    1,007
    That does not make any sense. The OP has had the car for six months.
    Brad
  6. Patrick Wong
    18,210
    6,517
    Most likely the 12V battery is dead. You have two choices:
    1. Find the dedicated positive jumpstart terminal in the main relay/fuse box next to the inverter. Apply the positive red 12V cable from your jump source to that terminal, attach the negative black cable to one of the nuts holding the strut behind the relay/fuse box. See if that brings the car to life.
    2. Crawl into the hatch. Remove the folding hatch floor. You will see the black tray over the tire. At the rear of that tray you will see a small door. Open that door. Now you can see the hatch locking mechanism. Look for a little lever which is the manual lock release. Move that lever while you push up on the hatch, to open the hatch.
    Once you have access to the 12V battery, replace it.
  7. bisco
    52,776
    it goes dead on the lot, and they charge it up when someone wants to see it. but adios amigo to these batteries after being disrespected.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Yep
    Used Prius sits in the lot for quite awhile as they don't sell that fast anymore and then you roll in and they rush out and jump start it and away you go.
    Hook a car charger to the front jump points. Under the black plastic fuse cover there's a red plastic cover. Open that cover and there's a metal vertical tab under it. That's the positive volt clamp to attach the red clamp of your charger. Use the strut nut right above that box as the negative.
    Soon as it's charged enough to open the hatch go buy a new battery and install it. There's 12,567 posts on this forum how to do that.
    Do not do not jump start it.
  9. strawbrad
    953
    1,007
    Really? The OP had the car for six months running fine after leaving the dealers lot. Dam dealer must have jump started a dead battery knowing the buyer would get only six months use out of it.
  10. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Lost his car six months ago. Didn't say when he bought this car.Dam you can't read a post.
