2006 Prius ice rattling acceleration only
Discussion in 'Gen 2 Prius Technical Discussion' started by Bryan Holloway, Aug 15, 2016.
  1. Bryan Holloway
    Bryan Holloway Junior Member
    43
    Fullerton, Ca
    i have been hearing a rattling noise coming from the engine under acceleration only. It isn't a super consistent rattle, seems to only happen when accelerating from lower speeds. And sometimes you don't hear and other times you do. It's not a bad rattle or knock it's more of a ticking/light rattling sound that is definitely abnormal.
    I know my brake accumulator is barking at me and the 3 way coolant valve is going bad as sometimes I get a constant pumping sound. I don't think these have anything to do with it but thought I'd mention it.
    I went ahead and replaced the water pump and pcv valve as I have 220k miles. The noise didn't go away. Anyone have any insight to this problem?
  2. b100
    b100 Member
    145
    75
    Netherlands
    My engine has a light rattle under cold accelerations too. If its warm is less noisy.
    If the radio is on you don't hear it.
    It sounds link valves. All the prius i drove have that same sound.
    Its only noticeable if you really listen to it.
    So the prius engine makes a very soft rattle noise when accelerating.
    If you think your sound is harder, its maybe a exhaust gasket that will rattle also under acceleration.
    And a question i might think you checkt already......hows you oil level?
    52,803
    check all along the exhaust for metal to metal touching or too close.
    b100 likes this.
  4. Bryan Holloway
    43
    Fullerton, Ca
    Oil level is good, but I am burning oil, and have run it pretty low before on accident awhile ago.
    Ill check that out and report back. I have had the cat off though and would imagine I would have seen it or changed it since I removed and reinstalled it.
    b100 and bisco like this.
  5. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Mine (2009 Gen 2, 93K) rattles after a cold start for the first few minutes. Once things warm up, the sound fades away.
    Data Daedalus and b100 like this.
