2006 Prius No Horn After OEM Clock Spring Swap
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dane Kaylor, Jun 10, 2018.
  1. Dane Kaylor
    Dane Kaylor New Member
    OKC
    Greetings all,
    I've been working on my wife's 220k miles 2006 Prius trying to get her horn back in working order since she loves to honk.
    Initial problem was:
    • Steering controls all worked (though no back lights)
    • Horn and lights would work with wheel turned a good degree
    Figured after 200K+ the clockspring had let go. Got it replaced with an OEM part and still have no horn. 10A fuse checks out, so now I'm assuming it's time to check the relay below the fuse and then the horn leads.
    I did get a faint horn sound with when I powered the car off and depressed the horn, though it was only instantaneous and couldn't get it reproduced.
    Any other tips would be greatly appreciated!
    52,886
    welcome!
    do the horn and lights still work at one degree off center?
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Was this a clock bring from Toyota?
    What was appropriate cost?
    Many if the really cheap ones have issues.
  4. Patrick Wong
    18,212
    6,529
    Why not apply 12V directly to the horn to verify that it works. Then work backwards to figure out where you have a loss of 12V between the relevant fuse and the horn.
    priusvid likes this.
  5. priusvid
    priusvid Junior Member
    32
    Calgary, Alberta
    I just did my clock spring but the wheel is now cocked to the right 2008, any solutions on how to line it up properly? Thx
  6. Patrick Wong
    18,212
    6,529
    Remove and reinstall the steering wheel.
  7. priusvid
    32
    Calgary, Alberta
    That’s an easy answer I was looking for ! Thanks
