2006 Prius not charging but works fine?
Discussion in 'Gen 2 Prius Technical Discussion' started by HC0994, Jun 17, 2017.
  1. HC0994
    HC0994 New Member
    So this happened a few days after I jumped a friend's car.
    4 warning signs light up on the dashboard: (!), VSC, check engine, and the red triangle. The car is still perfectly functional and has great mileage (48+ mpg).
    The next day, (!) and VSC disappeared, with only check engine and the red triangle remaining. The car is perfectly functional but the battery charge is not moving at all on the multifunction display. (There are yellow arrows going towards and away from the battery).
    I went to autozone and they said there is no error code on the computer.
    What could the problem be? Could it be the jump that causes it?
    52,863
    welcome!
    yes, how many bars on the battery icon? the auto zone reader doesn't do all prius trouble codes.
    Data Daedalus likes this.
  3. HC0994
    HC0994 New Member
    Thanks for replying. It was 2 bars (purple).
    52,863
    has it gone up? how much have you driven it? you might have blown a fuse, or the dc/dc converter.
  5. HC0994
    HC0994 New Member
    It went up to 4 bars (blue) one time but most of the time it stayed at 2 bars.
  6. bisco
    52,863
    you'll have to have toyota read the codes. there are threads here on how to check the fuses, and if the inverters blown, you can get salvage for low money.
  7. HC0994
    HC0994 New Member
    Thank you!
    Data Daedalus and bisco like this.
  8. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    Have you had the 12v battery tested?
