2006 Prius not responding to power button
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wtrail, Nov 29, 2022.
  1. wtrail
    wtrail Junior Member
    I have a 2006 Prius with the common "intermittent dead cluster" problem. Recently the driver side stator burned out in the transaxle due to a stuck coolant valve. I had these issues fixed at the dealership, and after completing the repair and road testing the vehicle they called me to come pick it up.
    When I got in the car, it did not respond to the power button. At that point the dash lights worked (or at least the "door ajar" light lit up when I had the driver door open.) I tried the power button a few times with and without the brake held, and I tried long-pressing the power button for sixty seconds - none of this yielded a response from the car.
    The tech connected his laptop and said he "found a communication error between the immobilizer and the ECU". By this point the cluster lights didn't work, and he said the dead cluster could be causing the issue. This doesn't really make sense to me - the cluster was working at the point that the car first failed to respond. I disconnected the battery a few times until the cluster lights came back on and had him repeat the test, and he pulled the same codes. At this point it was 4:30 and the dealership was closing so I left the car there.
    The following day, the car started up no problem for the tech. They repeated this a few times with no issues. But then this morning, it refused to start up the first time, but worked five minutes later after the tech went back into the dealership to get tools.
    Does anybody have a guess what's going on? The dealership is focused on the cluster issue, which doesn't seem likely to me. I'd like to avoid paying dealer labor rates and for an OEM cluster gauge, particularly since I doubt it will actually fix the problem.
  2. JC91006
    16,939
    8,647
    You have a combination meter failure, very common (cluster failure). Many shops can fix this issue for about $150, it's a very common fix for the Gen2 cars. The dealer can't fix this issue, they can just replace the part for $1000+
  3. wtrail
    I understand the costs of getting the cluster replaced at the dealership. The thing I'm concerned about is that my car now intermittently doesn't start at ALL. Are you saying the cluster issue can cause that?
  4. JC91006
    16,939
    8,647
    Yes the cluster can make the start button not function, many of the functions are related (shutting off and turning on)
  5. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Not trying to hijack this thread, but could you please tell us more about the above repair, like the OBD2 codes (aka DTCs) you had before authorizing the repair at the dealership, or what was printed on the dealership repair work order, including any parts and labor. Thank you.
  6. wtrail
    I don't recall the specific codes I pulled, but the text readout said generator failure. I was coming off the highway, there was a clunk, and the left side started grinding really bad along with a massive drop in power. I determined from googling the symptoms and code that it was most likely the stator, which the shop was able to confirm. While they were in there installing the replacement transaxle (which I got a decent deal on - a low-mileage part had just come out of a dead gen 2 at a different dealership) they found the stuck valve, which the tech says likely caused the failure in the first place.
    OK, thanks. I'm starting to think the capacitor burst and leaked conductive fluid onto the circuitry, which could cause an intermittent failure. I'm going to bring the car home and break down the dash, and see if I'm right. If there's no visible leakage issue I'll probably swap for a pre-programmed eBay board to be safe, but if there's some schmutz on there I'll clean it off with isopropyl, solder a new cap, and put it back together.
    SFO likes this.
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    A leaking capacitor is possible, but I haven't seen it or heard of it happening like that. The cap on my 2006 looked fine- I think the car powered on/off ok. Just had no instrument display and no warning lights either.
    My understanding is the cap goes "out of spec", which allows too much voltage fluctuation when the CM turns on and that causes the microprocessor (cpu) to "hang" or lock up.
    There's a number of variables here: battery voltage at power up, temperature, and how "bad" the cap is- all can affect exactly where in the boot process the cpu hangs and might account for the "differences" in symptoms.
    Short form, you have A known problem that can cause most of your symptoms. You won't know if it's THE problem (or even the ONLY problem) until you fix it.
  8. Tombukt2
    Tombukt2 Senior Member
    13,878
    2,521
    Durham NC
    During my two years of driving my '08 with no cluster or extremely intermittent cluster like would be off for days My start button always worked sometimes to get the car to turn off I had to hold the start button until everything went blank. But my next question to the original poster here you're 12 volt battery is completely within spec no issues it'll pass a load test in other words?
  9. wtrail
    I've been driving this '06 since 2020 with a similarly highly intermittent cluster and it's always started. That's why I was skeptical this was the issue! But after looking at some electronic schematics it does appear a lot of relevant wiring runs through the cluster board, including the immobilizer, so I've ordered a replacement cluster with a programmed odometer to be safe.
    The 12v is brand new and tested fine at the dealership after it failed to start. I unfortunately had to replace it before taking it to the dealership because after the stator blew, I foolishly left my OBD scanner plugged in under the dash while I took a different vehicle on a trip. By the time I got back I had drained the 12v so far that it was beyond saving.
    And that's how I ended up with a new $220 AGM for a car that doesn't start. What a world.
  10. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Thank you for the replay. Curious what mileage was at failure, and if you had ever changed the transmission fluid before.
    Dealerships rarely install used parts. Where in the USA, and what was the approximate labor cost for the replacement?
    Does anyone know what that "stuck valve" is, or a part # ?
  11. mr_guy_mann
    4,120
    2,018
    NJ-USA
    The only "valve" I can think of for the cooling system is the "3-way" control valve- which has nothing to do with the transaxle cooling anyway.
    SFO likes this.
  12. James Analytic
    416
    63
    Michigan
    Nothing is coming to mind in regards to a "stuck valve" in my mind as well, maybe dead inverter pump? P0A92 code situation maybe?
    I just found another 06 that was reported as the car did not start after the place that installed the breathalyzer thing removed the breathalyzer immobilizer. The owners could do nothing other than tow the Prius to their property and it has sat every since.
    I swapped in a 12V battery to test and the Power button does not respond. No LED power appears. I didn't have a multimeter with me to test anything. The fob seems to work as I placed in the slot and the flashing red Prius Immobilizer car key icon LED stopped flashing. The fob battery was dead however and no one had a small enough screw driver to swap in a good battery.
    Anyone every worked on a gen 2 or other with a breathalyzer installed and then removed and a no start situation?
  13. Tombukt2
    13,878
    2,521
    Durham NC
    A remote starter should be similar wiring diagram . You should be able to see wer it was easily looking for butt splicers. They do not have to hide connections as the law backs this up you prosecuted for lifting hood almost believe it. 9 would guess the just left start circuit open not connected etc. After 5 min they just say call tow not our issue .
    James Analytic likes this.
