2006 prius red triangle with no codes appearing
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Miguel Olivares, Sep 1, 2016.
  1. Miguel Olivares
    Miguel Olivares Junior Member
    56
    Oakland
    Just started a while ago. First it was the master break solenoid, got that replaced. Car drove fine but the light came up.
    Just had a shop diagnose it and said it was the inverter coolant for the main hybrid battery.
    Replaced it but the triangle is still there.
    My OBD2 reader is showing no codes. I remove the the triangle using the dongle but it comes back up immediately.
    The technisian doesnt wanna refund me for the false diagnosis, what else do you guys think could be wrong?
  2. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    2006 or 2008? Miles?
    If under CARB warranty 10-yr 150k miles get over to Toyota service shop
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    If the triangle is there, there is a code.
    The reader needs to be able to read the code.
    Get techstream or torque. Or take it to a dealer or independent hybrid tech.
    Art's Automotive is up in Berkeley, CA.
    Or try Pat's Garage or Luscious Garage in SF.
  4. Miguel Olivares
    56
    Oakland
    2006 :0 i just callled and left a message to the dealership
  5. Miguel Olivares
    56
    Oakland
    I ordered a techstream 2 days ago.
    In order to use, id have to install the software on my computer and connect the dongle to the prius correct?
  6. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    A old xp based laptop would be the ticket. The techstream software disc you receive may have malware on it, better to isolate to a laptop no longer used for daily service.
  7. Miguel Olivares
    56
    Oakland
    I wish my current laptop had xp lol
    I undersyand then, any old computer will work. JUst waiting on tracking!!!
  8. Miguel Olivares
    56
    Oakland
    I got the cable and software to work and it gave me the 3 error codes
    P0A2D
    C1310
    B1421
    I can't seem to find anything on these.
  9. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    If you insert these codes into the Prius Chat search, you will find certain answers for each code. P0A2D seems to suggest a temp value is too high or not reading due to loose wiring or bad connection.
  10. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    P0A2D
    https://techinfo.toyota.com/t3Portal/document/rm/RM1290U/xhtml/RM000000Y4V017X.html?sisuffix=ff&locale=en&siid=1472779221392
    C1310
    DTC C1310/51 MALFUNCTION IN HV SYSTEM
    CIRCUIT DESCRIPTIONThe skid control ECU communicates with the hybrid control ECU and controls braking force according to the motor's regenerative force. The skid control ECU sends Enhanced VSC signal to the hybrid control ECU and inputs operating signal from the hybrid control ECU. The skid control ECU uses CAN communication for communication with the hybrid control ECU. If a communication malfunction is memorized, the skid control ECU prohibits Enhanced VSC operation and a part of ECB control by fail safe function.
    C1310/51 156
    The traction control prohibition signal is received for at least 0.07 sec. when IG2 terminal voltage is 10.5V or more for at least 1.5 sec. and communication with hybrid control computer is valid.
    Problem Area
    Hybrid control system
    (Enhanced VSC)
    This DTC is output from the skid control ECU when the hybrid control ECU sends a malfunction signal to the skid control ECU.
    INSPECTION PROCEDURE:
    CHECK HYBRID CONTROL SYSTEM
    B1421
    Solar sensor, not sensing sunlight, garaged while checking with techstream likely. No worry.
  11. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    Here is a thread regarding P0A2D
    P0A2D, Technical opinion deeply appreciated | PriusChat
