2006 Prius - Replace engine from 2004 Prius
Discussion in 'Gen 2 Prius Technical Discussion' started by financer83rs, Oct 26, 2017.
  1. financer83rs
    financer83rs Junior Member
    Maine
    Good afternoon - I have a 2006 Prius with 208,000 miles that has a very noisy valve train. I have checked the lifters gaps and all appear within tolerance. This noise has been present for the last 10,000 miles. I have an opportunity to purchase a 2004 Prius running intact with 122,000 miles that sounds marvelous. The price is $1,000. The work does not scare me as I have a home shop with a lift and have done similar work on conventional cars dozes of times. Can anyone tell me if this is a direct swap? Can I swap the whole unit intact from the 04 to the 06?
    Expertise will be greatly appreciated.
  2. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I think both engines are compatible with each other. They're both gen2 1NZ, or 2NZ engines, which should fit, without any modifications.
    PS: You could also have taken pictures of the donor engine, and compare with your car, for any differences you might notice.
    Once again, both engines would work fine.
    Dxta
  3. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    $1k for a used Prius engine is about 3 TIMES more than retail. We can buy them all day in TX for $350 w/90 day warranty.
