2006 Prius Smart Key fob issues
Discussion in 'Gen 2 Prius Technical Discussion' started by sli, Aug 22, 2021.
Tags:
  1. sli
    sli Junior Member
    I am the original owner of a 2006 Prius.
    If I put battery in the key fob, it will occasionally trigger the car alarm. However neither lock/unlock buttons work consistently. The lock button works every now and then. I can insert the key fob into the key slot and can start the car.
    By the way, the tiny LED in the key fob blinks when I have a battery in it. What does that indicate?
    That is my only key now. I understand without a fully functional smart key fob, I can't even get the car to accept a replacement fob by doing the "chicken dance".
    Any suggestion will be appreciated.
    TIA.
  2. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    It indicates the fob battery is low. It needs to be replaced. Check any new battery with a voltmeter, especially these CR2032 button batteries, as there are too many new batteries that have sat for too long and are in fact flat when sold. A new CR2032 should be 3.2 - 3.4 V when new. If they are 2.9 V (or lower) you will have problems with your key fob.
  3. sli
    sli Junior Member
    Thanks, I will double check.
