2006 prius sudden death
Discussion in 'Gen 2 Prius Main Forum' started by Tollehouse, Dec 12, 2011.
  1. Tollehouse
    Tollehouse Junior Member
    West Covina California
    My Prius was running great. Started it up 6 times this morning. Took it in to have the oil changed, ok. Went to Costco to get the tires rotated and when they tried to start it, it just would not turn on. Had 3 different AAA guys try to jump it. said the battery showed full charge but it would not start. Had it towed to Longo's for diagnosis. It has been great up until now. Minimal maintenance. Still has the original brakes at 122K. Good quality.
  2. Gurple42
    Gurple42 New Member
    354
    Santa Monica, Ca.
    Good luck, hope it turns out to be a minor (under $1000) problem.
  3. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Ever had the 12 volt battery changed? If not, it's likely it's bad.
    The 12 volt on a Prius does NOT start the ICE (internal combustion engine) so you'll never experience symptoms such as slow cranking or starter being unable to turn the ICE.
    As for why I wouldn't turn on when being jumped, don't know.
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Scenario 1: oil overfill has caused P3191. Does the engine turn over at all?
    Scenario 2: CostCo guys messed up, discharged the 12V, did a reverse polarity jump, fried something, and now the car is quite dead.
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    WOW, we have different definitions for the word "minor". :D
  6. Oldwolf
    Oldwolf Prius Enthusiast
    826
    110
    NC
    2016 Prius v wagon
    There is a way to check your 12V battery voltage using the MFD. Look it up otherwise check it with a volt meter. I still have the original 12V batery in my 2005. Voltage shows it is good (so far).
  7. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    $1,000 per year is cheaper than a new car. ;)
  8. richard schumacher
    7,686
    1,068
    United States
    Or the oil change monkey didn't install the drain plug correctly. *Always* wait a few minutes with the car off, then check the oil level yourself before driving away from every oil change. Doing this can save a lot of grief.
  9. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
