2006 Prius will not Start
Discussion in 'Gen 2 Prius Technical Discussion' started by zakkotun, Sep 30, 2018.
Tags:
  1. zakkotun
    zakkotun Junior Member
    Houston, Texas
    My 2005 Prius will not crank.
    No light on the dashboard, no display, no radio and when I press the start button the check engine flashes twice. I saw on youtube where someone recommends replacing the motherboard on the instrument cluster, so I swap the complete dashboard with my 2004 Prius. It didn't solve the problem.
    I have replaced the 12V battery with a new one from the dealer @ 12.68V
    I can not get any code because for lack of power
    I have checked the fuses and relays
    Somebody, please help. Thank You
  2. brdmb
    brdmb Junior Member
    17
    Ohio
    Did you try putting the key fob into the key slot? I just recently found the battery went dead on my remote key fob and was flashing a yellow car symbol with a key on it (saying that it couldn't find a key in the car) when I tried to start. Stuck the fob in the slot, and it started right up.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Although it's difficult to troubleshoot long distance, the first thing I would do is check to see if you have 12.x volts at the jump terminal at the engine compartment fuse box. The heavy cable from the 12v battery (+) post connects there. That is the distribution point for all 12v.
  4. Al Bundy
    Al Bundy Member
    140
    69
    florida
    the orange safety plug is also a fuse.. might want to check it or swap it with your other car..
    was the car operating normally before this?
    parked outside? might have a rodent eating your wires always good to clean the ground from the 12 volt battery to the body
    good luck
  5. Al Bundy
    Al Bundy Member
    140
    69
    florida
    might want to read through this post, seems to be a similar problem
    Prius won't start and check engine light appears | PriusChat
  6. JC91006
    16,933
    8,643
    What's the history on this car? Did it suddenly start doing what you're describing?
    Raytheeagle likes this.
  7. zakkotun
    Houston, Texas
    History: Milage 145,000 I owned the car for 3 years. Reconditioned the Hybrid Battery 1 year ago. Did it myself and balanced it.
    The vehicle was running well with no code before this. What's Done: I checked the 12-volt battery in the back with backlash open 12.80.
    it's a new one from Toyota dealer, checked the front positive with the ground to the body 12.80 but steady at 12.79. I checked all fuses and they are OK.
    I just found the Problem, talking Fuse, the Glass Fuse DC/DC 100A is broken. I am happy I went back and found it.
    Can somebody tell me how to Fix it? Regards.
