2006 Prius won't start after running out of gas
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 4Gen2, Sep 14, 2019.
  1. bisco
    51,961
    i think your on top of it
  2. 4Gen2
    4Gen2 Junior Member
    16
    Durham, NC
    My daughter is getting a battery from Green Bean. Thanks everyone, -- Larry
    51,961
    all the best to her!(y)
  4. 4Gen2
    4Gen2 Junior Member
    16
    Durham, NC
    Thanks Bisco!
    Green Bean installed the battery and it still won't start -- throwing P0A0F. Dealer is going to start looking tomorrow but I may run over and clean the MAF first.
  5. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Did you get the old gas out and put fresh gas in?
  6. 4Gen2
    4Gen2 Junior Member
    16
    Durham, NC
    How -- with a siphon? The gas is all fresh except the small amt. that was in the can I borrowed -- less than 1/2 G. But if that was crud it certainly could be causing a problem. I'm not sure how to clean it all out without removing the gas tank.
  7. Skibob
    2,912
    1,505
    Northern California
    You could disconnect the fuel line and press the start button without your foot on the brake. I think that gets the fuel pump to run. Just have a charger on your 12 volt while your doing it.
    Paul Schenck likes this.
  8. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    This thread fascinates me. The new battery would turn Mg1 and try to start the engine. Then if there was no gas then the code P0A0F
    The way to check the fuel pump is do disconnect the fuel line ( back behind the passenger rear wheel IMG_2314.JPG IMG_2314.JPG
    I suppose you could check it at the engine too.
    There is no point to checking that the fuel pump is working if the new battery isn’t cranking MG1
    If MG1 is turning the engine over and the fuel is pumping then the clog is in the injectors right?
    iPhone ?
  9. 4Gen2
    4Gen2 Junior Member
    16
    Durham, NC
    Our friend just diagnosed it as water in the gas. SO, the problem was the small amt. of "gas" in the can I borrowed.
    She's going to force the fuel pump on to drain the tank, then refill. Fingers crossed.
  10. Paul Schenck
    523
    306
    Fresno, California
    That makes good sense thanks for checking back in
    iPhone ?
  11. bisco
    51,961
    good luck!(y)
  12. 4Gen2
    4Gen2 Junior Member
    16
    Durham, NC
    She's back on the road!
    Our friend recommended we add a bottle of fuel system cleaner to the tank -- any recommendations?
    Raytheeagle and bisco like this.
  13. bisco
    51,961
    congrats! you're friend is a genius!(y)
  14. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    BG Products 44K(y).
