2006 Prius would not go into drive
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Owner of "Little Green", Aug 13, 2022.
  1. Owner of "Little Green"
    Owner of "Little Green" Junior Member
    Boulder, CO 80304, USA
    This week my car would not go into drive when starting as usual with foot on brake. I turned it off and on, no luck, pressed the left brake in and then out again and I got it into neutral, but not drive and it started rolling a bit. Then eventually after a few minutes went into drive and has been fine for the last few days. I did the in car
    12V battery check and it was 12.3, 12 and 14.2. The onscreen hybrid battery level showed 2 blue bars this week. It was wicked hot, 95 degrees, running AC at top speed but only driving less than 15 minutes each trip. Any clue why my car wouldn't go into drive? This have never happened before. Hybrid battery was replaced less than 2 years ago.
  2. PriusCamper
    PriusCamper Senior Member
    13,468
    5,437
    Pacific Northwest, USA
    Your 12v is low and that can create the symptoms you describe. Get your 12v battery charged up, or buy a charger so you can do that: https://www.ebay.com/itm/354203591176 Or if that doesn't work, this is the 12v I recommend: https://ebay.us/5n8222 Let me know if you need details on easiest way to install it as it's a slightly different battery type that lasts longer.
  3. Owner of "Little Green"
    Thanks! So how long do you have to keep the battery charger on? How do you tell whether you just buy a battery charger or get a new battery? Whenever I use the in-car diagnostic my readings are 12.3, 12 and 14.2, with the last being with the car turned completely on. The battery you gave the link to is cheaper than the Toyota True Start Battery (by about $100) which is also supposed to last a long time. I don't think I could install any of them, but might be able to find someone who could or maybe Boulder Hybrids would do it.
  4. PriusCamper
    13,468
    5,437
    This charger and most decent chargers these days have a processor to give the battery the exact amount of charge it needs based on how fully charged or empty it is. And during covid, I met lots of people who had batteries that were only a couple years old that died on them and had to be replaced because if you aren't driving your Prius everyday, your 12v battery is going to not get enough time to recharge when the vehicle is on.
  5. Owner of "Little Green"
    Took the car in today and the battery was bad so I thought I better not wait to order one and had them put one in.
  6. Owner of "Little Green"
    Thanks everyone for all your kind help with this issue. I learned so much from all of you! :)
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    or the shifter is just acting stupid
  8. Owner of "Little Green"
    I was hoping that was the problem! But unfortunately I had the battery tested and it was bad and had to get a new one.
  9. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    I do hope that your symptoms never reappear. Just keep in mind the Toyota repair manual typical states in every troubleshooting procedure to check voltage on the 12v circuit first. Right or wrong, they require no action to be taken unless it's <11 volts. I've seen a Gen 2 fire up completely normal even when the 12v battery was at 8 volts. Once the car goes to "ready", which yours did, the 12 volt system is taken over by the 201 volt HV battery and DC-DC converter (the prius version of an alternator), which is why your voltage jumped to 14.2 volts. After this, if you car wasn't going into Drive, it's very unlikely that it was due to the 12v circuit being at 14.2 volts.
