2006 Prius wuth p1121 error code and long trip tomorrow!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ValleyBoy, Jul 19, 2013.
  1. Mr.Electric
    Mr.Electric Member
    287
    103
    San Francisco
    You should be fine since the light is off. That valve directs coolant to the thermos like canister in the fender. It is probably stuck, could possibly be the source of the leak. Unless you run out of coolant it should not be an issue. The thermos saves hot coolant for the next cold start. Toyota got rid of that system on the gen3
    Turn off signatures in Tapatalk Tapatalk
  2. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    Valley Boy.
    Just noticed this was back in July except for the last post.
    What was the final outcome of your problem?
