2006 Red Triangle Light, Check Engine, and Hybrid Cooling Intake Vent
Discussion in 'Gen 2 Prius Technical Discussion' started by gene12943, May 3, 2017.
  1. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Welcome!
    How many miles do you currently have?
    Have you checked the engine oil and radiator fluid lately?
    Did the dealer offer you a free inspection? if not, you should've been given a print out/receipt for the work performed (including diagnostic codes) and any estimates for repair.
    The answer to your question is yes, the inverter coolant pump can offer up a large number of lights.
    Are you a DIY'er, have a friend who is, or know of an existing Hybrid Mechanic that you trust? if not, then you might want to let the dealer tackle this problem.
    Most mechanics should be able to tackle this repair, but purging or bleeding air after replacement might be tricky for some.
    Raytheeagle likes this.
  2. KellyinPas
    KellyinPas New Member
    Four Touring
  3. KellyinPas
    Four Touring
    That is exactly what happened- $1,100! Thank you very much for the info everyone. (What is really annoying is that I get it back last night and the flashing tire pressure warning light comes on this morn but I guess they didn’t check it)
    SFO likes this.
