2006 SKS key; 1 key; buttons don't work
Discussion in 'Gen 2 Prius Main Forum' started by gptoyz, Aug 4, 2017.
  1. gptoyz
    gptoyz Junior Member
    85
    17
    los altos
    Hi everyone,
    I just bought my friend's 06 Prius to supplement my C. With 207k miles, the car has been great. He had only one SKS key but the buttons don't work. I think the panic works because it's activated the alarm which I can't shut off.
    The key works in the slot and the proximity features work:
    - push button lock
    - hand unlock
    - not in slot push button start
    The led does work when I'm near the car.
    I replaced the battery in the key and the 12v on the car has 12.2v with the lights on
    Right now, I only have 1 key, I'm planning to grab another off of eBay when I get a chance. I was going to try the chicken dance but wanted to make sure that I can't accidentally deregister the key or lose any more functionality.
  2. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Even when key is away from the car pressing lock or unlock button should get the red light in the key light up. If it doesn’t maybe you just have a stuck down button on key. They can be force up with a knife or correctly fixed by just changing the key shell.
  3. gptoyz
    85
    17
    los altos
    The buttons physically press but they don't do anything
    iPhone ?
  4. valde3
    2,002
    750
    Finland
    Do you feel the actual switch under rubber working? If not try to leaver the sides of the rubber to get the buttons up a bit.
    In any case red light on the key not lightin when pressing buttons profess that the fault is in your key.
  5. gptoyz
    85
    17
    los altos
    He key is pretty rough, but the tactile response is there so I'm pretty sure you are correct in that the key itself is probably damaged. The buttons are exposed.
    iPhone ?
  6. gptoyz
    85
    17
    los altos
    So the rape button definitely works and triggers the led
    iPhone ?
  7. dolj
    dolj Senior Member
    8,648
    4,399
    Wellington, New Zealand
    The lock/unlock contacts on the circuit board could be insulated with pocket lint as the protective cover has worn through. You could open up the fob and clean the circuit board (with particular focus on the lock/unlock buttons) with some PCB cleaner. While you have it open check at the front of the bottom half of the case for a rectangular piece of what looks like plastic. This is the RFID chip that is needed to start the car when the key is inserted. if you can get the buttons to work, buy a new shell case off fleabay/Amazon and swap the innards (including the RFID chip) over to the new case.
    I read where it was done (loosing functionality), but only by not following the correct procedure. However, you need a fully functioning key fob to do the chicken dance correctly, and pushing the lock/unlock buttons is a key part of the procedure at the end, so if they don't work you cannot complete the procedure. Make sure the lock/unlock works correctly on your car before trying the "chicken dance".
  8. gptoyz
    85
    17
    los altos
    So quick update, the key does work ... sort of....I guess the rape button has something in it that's causing it to sometimes stick or something. So if I wiggle it around it will eventually allow the other 2 buttons to work. it's very annoying because the alarm button is hyper sensitive
