2006 throwing up service lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by misterdean, Aug 5, 2026 at 10:11 PM.
  1. misterdean
    misterdean Member
    205
    29
    FL
    red triangle, VSC, and ! in the circle. car won't start unless i disconnect the battery. drives fine after battery disconnected. i'm reading inverter pump. the fluid is moving, very slightly. not sure how much it's suppose to move. also hearing the cheapo code scanners at auto zone are not able to pull codes that are red triangle / hybrid battery related.
    thoughts?
    #1 misterdean, Aug 5, 2026 at 10:11 PM
  2. ChapmanF
    19,016
