2006 Toyota Prius Dash Lights Diagnostic Help?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jacob Thompson, May 31, 2023.
  1. Jacob Thompson
    Jacob Thompson New Member
    Illinois
    Hello, mechanics of Reddit! Today is a scorching 90 degrees and a few car lights on my dash turned on (Pictures included). These lights appeared as I waited at a train and had a long line for a pharmacy drive thru. The battery on the center console keeps fluctuating in charge and the fan kicks on in the back (I believe that's for the battery). This said, I just replaced that battery not too long ago, and I was curious if it needs to be replaced again or is it the heat? Could the problem be something else? Whatever it might be, I hope to have an answer because these lights worry me! Thank you for your time :)
    Edit: Car started having difficulties accelerating as I got home
  2. Brian1954
    Brian1954 Senior Member
    1,755
    683
    South Central PA, USA
    With all the warning lights on the dash, you will have trouble codes that need to be read with a gen2 compatible scanner. Retrieving the trouble codes will tell you how to proceed with troubleshooting the problem(s). That being said, everything that you have described points to a problem with the HV battery.
    SFO likes this.
    51,103
    reddit?
    where did you buy the replacement battery?
  4. PriusCamper
    PriusCamper Senior Member
    12,018
    4,882
    Pacific Northwest, USA
    Reddit is social media @bisco It's something the kids do to get answers to questions, as well as to bully their friends and foes...
  5. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Welcome to PriusChat!!
    It may not solve your issue, but when was the last time you inspected or cleaned the HV battery fan?
    FYI : you're moderated until you've posted 5 times.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    3,954
    1,905
    NJ-USA
    PriusCamper likes this.
