2006 vs. 2007-2009 Airbag Question
Discussion in 'Gen 2 Prius Main Forum' started by hunt251, Jul 17, 2017.
  1. hunt251
    hunt251 New Member
    Maryland
    I am in the process of buying a used Prius. I am considering vehicles between 2007-2009. (Yes, I know the possibilities of replacing the battery, etc.)
    But I have seen some nicely priced 2006's with relatively low mileage. I know that Toyota added various standard airbags in the 07' model and I'm scared to get a Prius under 07' for just that reason.
    Are my fears legitimate? Do the standard airbags add THAT much safety to the car?
    UPDATE: I will not risk it and will only look at vehicles with the side airbags.
    #1 hunt251, Jul 17, 2017
  2. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    Speaking from my memory of my deceased 2005:
    There was a crash rating difference (improved one "star", I think) when the full set of air bags was equipped as compared to the base model standard equipment.
    You can find the full complement if air bags on older vehicles, but it would require one that was built with an option package that included them.
    hunt251 likes this.
  3. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    My 2006 has side and side head airbags, as well as stability control. As stated above, these were optional items. If I were you I would not buy a Prius without these safety features. I'm not sure what if any extra airbags were added in 2007, unless perhaps the side airbags became standard. Apparently these safety features were optional all the way back to 2004.
    hunt251 likes this.
  4. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    2006 Toyota Prius
    To answer your original question, In IIHS crash testing for the 2006 Prius, the difference between a "Good" and "Poor" rating is whether the car had side airbags or not.
    hunt251 likes this.
  5. hunt251
    hunt251 New Member
    Maryland
    Thank you so much for the information.
    Guess I'm not looking at 2006s (without the optional airbags) anymore. It's crazy how today's standard safety features were optional years ago.
  6. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    IMG_3448.JPG No problem! When I was shopping for my GenII those safety features were also a must have on my list. I would also argue that stability control is also a must have as well. In snow and ice, it can be a lifesaver. The way to know that a GenII has stability control is the presence of the stability control light...this is a poor picture but it's the yellow light on the bottom left, car with 2 squiggly lines underneath.
    hunt251 likes this.
  7. wrprice
    415
    308
    Houston, TX
    Four Touring
    My memory must be going bad. I thought the squiggly lines were for traction control (standard) and stability control was the VSC light.
    hunt251 and Merkey like this.
  8. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    Lol, you are right, it IS the VSC light that you're looking for! It was getting late, and my brain farted big time last night.
    hunt251 likes this.
  9. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    Accidental double post
  10. hunt251
    hunt251 New Member
    Maryland
    So how would I find the VSC light?
  11. hunt251
    hunt251 New Member
    Maryland
    How do I find the VSC light? I know that it's on the dashboard, but I'm sure it doesn't stay on.
  12. dolj
    dolj Senior Member
    8,616
    4,375
    Wellington, New Zealand
    Press the power button twice with your foot OFF the brake to get to IG-ON mode. All the lights (except the Master Caution (Triangle with ! in the middle)) come on. When you are finished, press the power button once more to switch off.
    Rph74 and hunt251 like this.
  13. hunt251
    hunt251 New Member
    Maryland
    Thanks!
