2006 with 98,0000 Hybrid battery failure. Warranty?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JaxTom, Mar 11, 2013.
  1. doomteam1
    doomteam1 Junior Member
    32
    Highland, Ca
    how did you know your hybrid battery was out? did it run a certain way?
  2. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Well, according to the OP:
    The hybrid battery fan was running at full blast (not a good sign at all) and the dash was lit up like a Christmas tree.
    OP didnt mention any driveability concerns, but most people say when their traction battery is on the way out, the ICE runs more, noticeably less power, and the energy display shows the traction battery discharging and recharging very quickly. Good news is the ECU's monitor the traction battery like a parent with their first baby. It monitors voltage delta pretty closely and I think I read something like if a cell or block is off .1v, it sets DTC's and lights up the dash.
  3. JaxTom
    JaxTom Junior Member
    Jacksonville, FL
    2013 Prius v wagon
    In hindsight, I do remember the few times I drove it recently (it's the wife's car) that the ICE was running more than I remembered, and it seemed "lifeless". I didn't monitor the energy display.
    We had never reset the MPG indicator. So we could say what the lifetime mileage was. It was 49.9. Had been over 50 until set of tires #2 (not low resistance) drug us down. But even with Ecopia's it never budged.
    But the MPG reset when the battery was changed and we are at 55.5 MPG in the 150 miles since the replacement.
  4. JaxTom
    Jacksonville, FL
    2013 Prius v wagon
    OK, just ran the test. I guess it failed. First reading 12.1 2nd 11.7 , 3rd 14.1
  5. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    Yup, that's a fail...except the third value is the inverter voltage and is near correct. Get the 12v battery replaced and your mpg should go up...YMMV.
  6. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    Also, PLEASE change your transaxle oil. The transaxle is more expensive to replace than the batteries!!!
  7. JaxTom
    Jacksonville, FL
    2013 Prius v wagon
    Will do. Going to do all the stuff mentioned on this thread.
  8. doomteam1
    32
    Highland, Ca
    Looks like i have to call the dealer.
    My car when it went out showed the same symptoms. The backseat vent went on. Lights went crazy and battery was showing it going on and off crazy. Is there an at home test to find out or is it a dealer only test.
  9. MJFrog
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    You can get codes read at many local auto parts stores or your mechanic might be able to get them...post them here. However, your first step isn't to call the dealer. Your first step should be to rule out the 12v battery as being bad. If your's is still the original--it's toast: replace it and see if the symptoms improve or go away. Only then take it to the Stealership for HV battery testing.
  10. doomteam1
    32
    Highland, Ca
    It was replaced a few days ago, and then this stuff happened.
  11. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Apparently it was replaced twice already wasn't it. Once with a new Optima from autozone, and then again by the dealer about 100 miles later (who said that they had to replace it because it was "incompatible", along with about $850 worth of other work that did nothing to solve doomteams problem). This is according to his post here: 2004 Prius Warning LIght and Engine lights | PriusChat
    If you have any options at all then please stay well away from that dealer! Monitor the performance of your HV battery for a while and see how it plays out. Look for things like very rapid changes in state of charge (the blue and green bars on the battery display) as well as the battery fan in the rear vent. Yes there are some simple tests you can do, I suggest you monitor the things I've mention and start a new thread about this. You definitely want to try and figure out as much as possible about the problem for yourself before going anyway near that dealer, because they sound clueless.
  12. doomteam1
    32
    Highland, Ca
    There is another toyota dealer about 2miles farther. And yes it has been replaced twice. In a single drive of 5miles the batter charge changes from fully charged to one bar above empty.
  13. LT1
    LT1 Junior Member
    Thats awesome you got it replaced for free, im getting worried because mine is going on 170,000 miles on orginal Hybrid Battery. dont know how much longer it will last :unsure:
  14. JaxTom
    Jacksonville, FL
    2013 Prius v wagon
    So I was jotting down a list of things I need to do. I have 12v battery, Transaxle oil (which is same as ATF I assume), Inverter coolant, and Plugs/PCV.
    Anything else?
    Also, I had the recall done for the HV Water pump done in Feb 12 at 82,000 (Thanks for the link to the service history someone posted). Does that negate the need for the Inverter coolant change?
    I plan to get pricing from dealer and then compare them to Mellors. If Mellors saves me enough, maybe I'll make this a Prius Spruce Up/Spring Training combo trip. (It's 2.5 hours to Mellors)
  15. jdenenberg
    jdenenberg EE Professor
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If the dealer followed the TSB on the HV coolant pump, the coolant was drained and refilled at that time. The problem is that some dealers (who should lose their Toyota dealership) will clamp off the hoses and just add some new coolant to make up for lost coolant so its hard to determine the need unless you know what was done.
    You should also check into the ICE coolant as well. It was due to be drained and refilled at 100k miles. Bot loops should be refreshed every 50k miles thereafter with Toyota pink, pre-mixed, Super Long Life coolant.
    JeffD
  16. JaxTom
    Jacksonville, FL
    2013 Prius v wagon
    Thanks. I'll add the ICE coolant to the list. I guess I'll ask the dealer about the HV Coolant and trust them based on what they say.......
  17. jdenenberg
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    "Trust, but verify" - Renoldus Magnus
    JeffD
  18. JaxTom
    Jacksonville, FL
    2013 Prius v wagon
    I'm not sure how I can verify.... Anyone know about how much the Plugs/PCV might be?
  19. jdenenberg
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    How many gallons of SSL coolant were billed for in the records of the recall work? If less than 1, they didn't drain the coolant.
    JeffD
  20. JaxTom
    Jacksonville, FL
    2013 Prius v wagon
    Got estimate from dealer.....so far, Mellors has not responded to my request for estimate.
