2007 AC Fault Question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by satwood, Jun 26, 2017.
  1. satwood
    satwood Member
    107
    16
    Webster, MA, New England, USA
    2014 Prius v wagon
    Hi Everyone,
    I tried searching and only found partial details on this question so I'm putting out a new thread. 2007 Gen 2 with about 250K miles. AC stopped working with no prior problems - just cold one day then hot the next. Compressor is not making any noise. There is some refrigerant pressure at low side test port. Codes 21 and 23 appear on the MFD using the diagnostic mode. I think 21 is the sunlight sensor so I can ignore. Code 23 might be high pressure sensor according to online sources. I did not see an external high side sensor location on the system. Is it internal to the compressor? What's your best guess on what has happened? Is this a bad compressor or something I might be able to fix externally?
    Thanks for the help
    Steve
  2. JC91006
    16,935
    8,646
    Have you tried just recharging the AC system? You need to scan the codes on the car to get a clear picture of the actual failure.
    For instance, when your inverter pump fails, it'll cut off your AC when it gets hot. But there's nothing wrong with the AC system
  3. satwood
    satwood Member
    107
    16
    2014 Prius v wagon
    Thanks for the suggestions. I have not tried a re-charge. Since the compressor won't start and I can see some pressure on the gauge on the low side port I did not want to put more in and overcharge. Do you know how much pressure I should read when the compressor is idle? The inverter coolant pump appeared to be running when I checked it and there are no engine DTCs or check engine light.
  4. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    If it gets low it will shut off to protect itself since the lubricant is in the freon. Real question is why did it get low?
    if that's the case the two main places they like to leak in the condenser behind the front grill and behind the firewall inside the cabin which is no fun to fix probably better to just keep recharging from time to time if the latter is the case.
  5. Patrick Wong
    18,210
    6,517
    Low side pressure should be ~30 psi.
