2007 Base model won’t shift gears (battery?)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Donna Curlin, Sep 7, 2021.
  1. Donna Curlin
    Donna Curlin New Member
    Germantown, TN, USA
    Anyone have a situation where their 2007 Prius starts up but won’t go into drive or reverse?
    You can temporarily fix it by disconnecting the battery in the trunk for about 5 minutes.
    then you can drive it just a little bit and the red triangle comes on along with a beep and the next time you start the car it won’t go in drive or reverse, again.
    And the circle continues.
    Any ideas before you spend a fortune at a dealership???
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Welcome to PriusChat!!
    How many miles on the vehicle / hybrid battery?
    It sounds like a HV leak, most likely in the HV battery case. If you used a OBD2 scanner on this vehicle, you may find DTC P0AA6 / 612.
    Post any retrieved OBD2 codes in this thread for further guidance, you will likely need a hybrid compatible OBD2 scanner.
    Here is the workup for P0AA6, notice how this DTC has related 3 digit INFs codes (subcodes), knowing the INF may help narrow down the issue and potentially save time and money during diagnostics/repairs : https://attachments.priuschat.com/attachment-files/2018/04/145252_2006_Prius_RM_-_P0AA6.pdf
    Here is an image to help visualize each of the INFs :
    Do you have, or someone that you might know, a DIY attitude and some basic tools?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    BUT.......before you get all worried about a problem with the hybrid battery,
    you really should check the 12 V battery and it's connections first.
