2007 Camry Hybrid
Discussion in 'Toyota Hybrids and EVs' started by PapaWill, Jan 29, 2020.
  1. PapaWill
    PapaWill Member
    137
    25
    Maui, Hawaii
    I just took the head off because I over heated the engine and blew the head gasket... I took the head off, the timing cover too, of course, I had the head resurfaced at a machine shop and replaced everything with new gaskets and seals. I set the timing chain according to manual. Both yellow marks on chain together on the cam gears and one yellow mark forthe crank shaft gear. Now it will not start. Not even a cough. Just engine turning over for about 5 seconds and no start. I cleared all codes with TS. Not sure where to start looking... any suggestions? Thanks in advance!
  2. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Check the 12v
    52,880
    any codes?
    Priuslover09 likes this.
  4. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I don’t think you can check for any codes if the car won’t turn on.
  5. bisco
    52,880
    will the engine turn over if the car won't turn on?
  6. PapaWill
    PapaWill Member
    137
    25
    Maui, Hawaii
    The problem was a weak 12 V battery! It started and now runs great and no codes (imagine that...) . Thank YOU all for your responses~!
    CamryDriver and bisco like this.
  7. bisco
    52,880
    congrats!(y)
  8. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Great!
