2007 cat converter replacement helpppp im clueless
Discussion in 'Gen 2 Prius Main Forum' started by Maryashanti, Jun 24, 2017.
  1. Maryashanti
    Maryashanti New Member
    New jersey
    i just bought a 2007 prius from a private seller. A day later the engine lights on. He said it was due to a cat converter sensor and no big deal. He said they cleaned the converter n it was fine. $110 later at a toyota dealership after they diagnosed it they said it cant be cleaned and needs to be replaced. They said part alone is $2000 and suggest i go to a local emmisions shop so its cheaper. Ive read some forums that say to just do the sensor. Car has 90,000 and i live in nj. What are your opinions?
  2. JC91006
    16,923
    8,634
    Buy a catalytic converter on Amazon for $82 and have a shop weld it on.
    MilkyWay and Scott56 like this.
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    The seller LIED to you.
    Catalytic converters can not be "cleaned".
    And the sensor(s) involved are not just for the converter.
    Call around to a few muffler shops in your area.
    Not sure I'd trust one for less than $100 from an unknown seller but you should be able to get one for a LOT less than $2K.
  4. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I'd get estimates from shops like Midas & Meineke as I'm not a mechanic & don't know what other parts I might need. At least you know what the Magnaflow sells for so you can compare the shop's price. I'd also check out an indy garage in the neighborhood.
  5. Daryl Tillman
    Daryl Tillman New Member
    Visalia Ca
    Three Touring
    Will this work in california?
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  7. Patrick Wong
    18,210
    6,517
    From that website:
    "Notes: EPA Ultra Direct Fit Converter -- Must Be Used With 55431 Resonator Assembly; Fits Fed. & Calif. Emissions Models.; Not legal for sale in the state of California. Not legal for use on California emission vehicles in New York. Legal for use on Federal/EPA emission vehicles in New York."
    I believe that all North American Prius are rated as compliant with CA emissions. If anyone living in the US has a 2G Prius whose emissions label indicates Federal only (not California) please take a photo and post.
  8. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Toyota and Subaru vehicles are KNOWN for logging "cat efficiency" codes at efficiency loss levels that are below what any testing can detect in real-world situations. Put another way, the ECM is hyper-sensitive to even a tiny efficiency loss of the converter.
    Aftermarket converters are a cr@pshoot at best and are widely reported to have lives measured in months, not years.
    There are MANY things on a modern vehicle that can cause FALSE cat efficiency codes, not the least of which are exhaust leaks, bad oxygen and air-fuel ratio sensors and excessive oil consumption over a long period of time.
    There are many reports of successful cat cleaning, I have never tried it nor do I know anyone who has.
    My suggestions:
    1) Rule out the potential of an exhaust leak
    2) Look up, in your favorite search engine, spark plug anti-foulers in the 18mm size and prepare to install two between the exhaust pipe of your car and the REAR (downstream) oxygen sensor after enlarging the holes in the adapters to allow the sensor to screw into them. This is 100% effective and is NOT any form of emissions cheating device or method. It simply evens out rapid changes in exhaust oxygen concentrations that can trigger FALSE cat efficiency dtcs on older vehicles where the emissions are completely within the regs.
    ih8spm and SFO like this.
  9. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Install both anti-foulers on the one rear sensor?
  10. 05PreeUs
    1,097
    565
    MSP
    Yes, stack them.
    SFO likes this.
  11. audiodave
    audiodave Active Member
    800
    272
    US
    California is dealership required only. So Anything you do will have to be done yourself. Like having a magnaflo one sent to a out of state friend then to you.....
  12. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    That could be for both NY and CA, though best to check.
    During my last smog check (locally), the tech went down on his hand and knee with a selfie mirror and visually checked my cat (from in front of the rear drivers side tire area) for oem goodness :eek:
    Raytheeagle likes this.
  13. audiodave
    800
    272
    US
    Wow, that didn't happen to me. I have the magnaflo. Gas station smog guy didn't say anything.
