2007 cut out while driving - no warning
Discussion in 'Gen 2 Prius Main Forum' started by Lindsay Mathieson, Jan 7, 2025.
  1. Lindsay Mathieson
    Lindsay Mathieson Junior Member
    37
    Brisbane, Australia
    Everything just died - lights, dash, engine, aircon, coasted to a stop and went into park, had to get towed. Only thing working is the door locks. Drivers side window is stuck 2" down.
    No warning symbols or alerts showed prior to this. Can't get a mechanic till next week :(
    Only issue prior was the aircon not cooling well. I did have the coolant pump replaced in Dec-23
    Have the Toshiba Tech Stream setup - will try to read codes tomorrow.
    Could it be as simple as a blown fuse?
    Update: 8-Jan
    Success! It was the AM2 Fuse, thank you all for the guidance.
    I got replacement fuses same day couriered from SuperAutoCheap - Courier cost more than the fuses :)
    Turned out to be unnecessary as the engine fuse block had spare fuses still, also the Fuse Puller which worked a lot better than the generic one I got.
    Electrics came back on, I was able to wind the windows up, took a punt and reversed the car back into my carport (Tow truck left us on the street).
    If I knew all this yesterday, I could have fixed it up on the spot.
    Red triangle came on briefly, then went away. I'm wondering if it will be ok to drive it the 10Km to my mechanic for a service/repair next week. Much less painful than another tow.
    #1 Lindsay Mathieson, Jan 7, 2025
  2. Tombukt2
    Tombukt2 Senior Member
    13,837
    2,514
    Durham NC
    It could be or the fusible link in the big fuse box the long clear strip I need to look through that real good and make sure there's also a fuse in the hybrid batteries orange plug. And you need to check the positive battery connection in the trunk under the plastic tray where the actual 12 volt battery is I would say at this point sounds like you have no power I mean do you have the problem in the car where the dash regularly goes black but the car still works? Not a lot to go on here just yet.
    Lindsay Mathieson likes this.
  3. Brian1954
    Brian1954 Senior Member
    2,668
    1,066
    South Central PA, USA
    Yes, it could be a blown fuse. Check the AM2 fuse in the fuse box under the hood of the car.
    What coolant pump was replaced? There are three different pumps in a Gen 2.
  4. BiomedO1
    BiomedO1 Senior Member
    4,550
    2,393
    Left Coast
    ^ Yep, sounds like one of the main fuses blew. It's summer down there, so if you have an electric AC compressor - disconnect it. It may be the cause of your short and blown main fuse.
    Hope this helps....
  5. Lindsay Mathieson
    37
    Brisbane, Australia
    Thanks for the fuse hint! will check - easy to find? Will dig through the car manual.
    The Inverter Coolant Pump.
    Brian1954 likes this.
  6. Lindsay Mathieson
    37
    Brisbane, Australia
    Car has been trouble free up to now, never had an issue with the dash.
    Thanks
  7. Lindsay Mathieson
    37
    Brisbane, Australia
    Yup, 32c / 90F and humid :(
    Car is stock, no modifications - would that mean an electric AC compressor? Where would I disconnect it?
    Thanks.
  8. Brian1954
    2,668
    1,066
    The inverter coolant pump is downstream of the AM2 fuse. If the fuse is bad, you may again have a bad inverter pump that needs to be replaced.
    The pump you purchased in Dec 2023, was it a Toyota OEM pump or an aftermarket pump? The aftermarket pumps are known to only working for a year or two.
  9. Lindsay Mathieson
    37
    Brisbane, Australia
    Pretty sure it was aftermarket :( It was done under warrantee by the dealer.
  10. Lindsay Mathieson
    37
    Brisbane, Australia
  11. Brian1954
    2,668
    1,066
    Check to see if the inverter coolant pump is working. Take the cap off the inverter coolant reservoir. Turn on the car on by pushing the start button twice without touching the brake peddle (accessory mode). If the pump is working, you should see some turbulence when you look down into the reservoir. You might also be able to hear the pump running.
  12. Lindsay Mathieson
    37
    Brisbane, Australia
    Yah, definitely the pump, no turbulence or noise at all. Also blew a fuse again.
    Guess I'll be getting another tow :)
    Thanks for all the help, has done a lot to calm my anxiety knowing what the issues are.
  13. Brian1954
    2,668
    1,066
    Make sure you get a new Toyota OEM pump for the replacement. It will last much longer than an aftermarket pump.
    You should be able to disconnect the wire to the inverter pump. Then you will not blow the AM2 fuse. You could then drive the car slowly to the shop for service. Do not use the AC when you have the pump disconnected. I know that there are threads in this forum that have pictures showing the connector that you need to take apart to disconnect the pump. Try doing a search in this forum to find the pictures.
    #13 Brian1954, Jan 7, 2025
  14. BiomedO1
    4,550
    2,393
    Left Coast
    one or more of your electrical motors are drawing too much energy, that's why you popped the AM2 fuse. Other than the two motors in your transmission, the AC compressor is third in current consumption on your car. You need to figure out what assembly is drawing too much power, otherwise you'll just pop that fuse again.
    Hope this helps....
  15. Brian1954
    2,668
    1,066
    Read post #12. The problem is the inverter coolant pump. It is a very common problem on a Gen 2 Prius.
    The AC compressor is not on the AM2 circuit.
    Lindsay Mathieson and BiomedO1 like this.
  16. BiomedO1
    4,550
    2,393
    Left Coast
    I was typing when that one came through... Slow typer :cry::sleep::whistle:
    Lindsay Mathieson and Brian1954 like this.
  17. mr_guy_mann
    mr_guy_mann Senior Member
    4,111
    2,011
    NJ-USA
    Here's a US spec Gen2 Prius. Unplugging the connector shown at top left will disable the inverter pump and stop blowing AM2. It's easier to reach than the connector on the pump itself.
  18. Lindsay Mathieson
    37
    Brisbane, Australia
    Thanks so much for this! Sorry for the late reply, been a madhouse here - multiple storms. including one just hours after getting the car under cover, after fixing the AM2 fuse, so you guys saved my car from getting hail damaged!
    Had deal with a tree down in my yard and just for shits and giggles, rescuing my idiot dog from attacking a 2m carpet python on the deck.
    Anyway, I finally got round to disconnecting the coolant pump electrics as per your instructions, seems to have done the trick - can start the car, drove it a little bit, the fuse did not blow. Will drive it to my mechanic for servicing tomorrow morning, just a 5km drive, so should be ok with no coolant pump for that.
    This forum has been a life saver, you guys are great.
  19. Lindsay Mathieson
    37
    Brisbane, Australia
    Update - got to the mechanic fine, he seemed to know his stuff, asked whether I disconnected the coolant pump. He's the main service centre for taxi's here, which are mainly Toyota Hybrids.
    Asked for a OEM Pump, he's going to try and source one.
    mr_guy_mann and Brian1954 like this.
  20. Lindsay Mathieson
    37
    Brisbane, Australia
    Just realised I never updated!
    Mechanic replaced the coolant pump with a OEM Toyota one for $340, did a general service, only needed to replace a couple of filters, said the rest of the car was fine. Total cost AU$750 and has run fine since, until today... but that's another post.
