2007 dash/speedo went dark
Discussion in 'Gen 2 Prius Technical Discussion' started by Budman241, Jan 14, 2017.
  1. Budman241
    Budman241 Junior Member
    Loxahatchee, FL
    Four Touring
    Hello all...
    Recently bought my used prius, 180,000 miles. I had a bunch of codes show up, so I wanted to clear them before going to AutoZone for a diagnostic. Disconnected the 12v for a while. Now my speedo would not come on at all. Drove it a coulpe hundred yards, in front of the house. Nothing. 2 beers and a hanful of nachos later, went back out and it was fine. Lost the red triangle, red car on the center display, but kept abs,vsc, brake, check engine, and now a green car. Drove it for 5 minutes fine. Now no dash display at all . Tips? Thanks in advance
  2. Budman241
    Loxahatchee, FL
    Four Touring
    Oh yeah... 2007 prius...
    52,855
    congrats and welcome!
    some have had a bad solder connection in the display. you can have the trouble codes read at a dealer.
  4. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    The HUD (heads up display) dash display goes black when it doesn't reset upon IG on or it is blown out. It may work after several restarts, IG on..
    My 04 gen2 HUD will go black on cold days. Once it warms up it works on a restart. It is doing that more this winter.
    One thing is it takes 3-5 seconds holding the power button to shut it off with no display. If it shuts off immediately that may lead to a different diagnosis.
    First try this, expose the 12 V battery. Remove the red +12 v connector cover, Unplug the larger connector. The release clip is on the bottom.
    This will reset the EUC's. After a minute plug it back in.
    The reason I suggest the +12 v connector is it makes for a cleaner connect. The ground connection screw sparks a lot.
    Make sure it it clicks when inserted. If it is loose nothing happens when you try to start it up.
    If that doesn't work then the display has to be repaired.
    You have to dissemble the dash and pull the display module. Youtube has instructions.
    On eBay there is a person who repairs the module if it has a bad reset circuit for $98.00
    Otherwise you have an expensive repair with Toyota.
  5. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    You probably have two issues. One is a well-documented problem with the CM (combination meter). Toyota has a nine-year warranty extension on this, but it's expired for your car. Your best option now is probably the $100 repair noted above.
    The bad CM will not give you all those warnings. Something else is going on, and you need the diagnostic codes. (Next time you want to get a diagnosis based on codes, do not erase the codes.) Autozone may not be able to read all the Prius-specific codes, so you may need to go the dealer or buy a Toyota scanner (look up Mini-VCI for an inexpensive option).
    valde3 likes this.
  6. Budman241
    Loxahatchee, FL
    Four Touring
    Update:
    The codes that I was able to get so far ( I'm getting the mini vci w/ techstream) were the O2 sensor, solved.. abs stuff not fixed yet...
    the HUD is still an issue, VERY sporadic. Watched a few youtube videos and I am going to replace the HUD soon. Until then I'll just reset the EUC now and then. Thanks for the input, it was very helpful and spot on. I love my prius even with it's faults!!
  7. Budman241
    Loxahatchee, FL
    Four Touring
    Oh yeah... also code showed that my coolant pump for the flux capacitor wasn't working. $60 later I now have fluid flowing in the reservoir and no red triangle! Just have to keep it under 88 mph unless I want to go back to the future
    andrewclaus likes this.
