2007 DC/DC Inverter/Converter replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by popptj2001, Sep 20, 2015.
  1. popptj2001
    popptj2001 Member
    79
    52
    My DC/DC inverter failed in my 2007. Code P0A94. I obtained a used inverter and instead of going through the hastle of removing the entire housing, draining fluids, etc......I removed all the electrical internals and transplanted them into the old housing. Relatively easy repair. Back on the road :)
  2. Patrick Wong
    18,210
    6,517
    A novel approach. Any photos of the assemblies that had been transplanted?
    Also, did something in particular provoke the DC/DC converter failure?
  3. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    That was the same approach Toyota took when dealing with the Highlander Hybrid inverter recall problem.
    donbright likes this.
    52,694
    well done!(y)
  5. popptj2001
    popptj2001 Member
    79
    52
    Everything was running perfectly, then all of a sudden red triangle with multiple other dashboard lights. No engine, only battery life, for about 1/2 mile and that was it. Dead. Disconnecting the battery/reset did not help me move an inch.
  6. Mrs.Diamond
    Mrs.Diamond Junior Member
    66
    Minneapolis, MN
    Did you find a solution?
  7. Prodigyplace
    12,708
    11,847
    Central Virginia
    Read the whole thread. The solution is in post 1.
    Raytheeagle likes this.
  8. Patrick Wong
    18,210
    6,517
    Hmm, it is not clear whether the events in post #5 occurred subsequent to the repair described in post #1.
    Prodigyplace likes this.
  9. Prodigyplace
    12,708
    11,847
    Central Virginia
    I assumed post 5 was a response to post 2.
    That was an assumption on my part though.
  10. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    I think I'd ha e to try this same method next time when I get an inverter job
    Mrs.Diamond likes this.
  11. Barry CLEMENTS
    Barry CLEMENTS Junior Member
    52
    Is this transplant as easy as it sounds? Is it just a plug and bolt job? Sounds almost too easy to be true?
