2007 difficulty starting
Discussion in 'Gen 2 Prius Main Forum' started by wakeman, Mar 3, 2013.
  1. wakeman
    wakeman Junior Member
    Philo, California
    3x in the past few weeks it has taken 10 minutes or so to start the car. the ready signal just doesn't come. All the dash lights come on too. Anyone had this problem?
  2. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    did you remember to have your foot on the brakes when hitting the start button?
  3. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
  4. usnavystgc
    3,159
    990
    Tucson, AZ
    Classic weak 12V battery symptoms.
  5. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    week 12v...H
  6. techntrek
    techntrek Member
    263
    84
    MD
    Or bad brake switch. You have the pedal depressed but the car doesn't know it. I say this assuming when you say "all the dash lights come on" you don't mean warning lights, just the normal ones.
  7. dale trout
    dale trout New Member
    mingo jct oh
    i have same problem all dash lights on won/t go into ready mode only once in awhile that it will start and bttery says full green motor will not shut down and go in battery mode engine stys running when i do get the ready light on
  8. bisco
    52,863
    you probably need a new hybrid battery, but start by pulling the trouble codes. or maybe a 12v test
  9. dale trout
    mingo jct oh
    i just put new 12 battery in i have 2 new ones and tried both of them and the hybrid battery is reading 222.1 volts just put 10 new cells in it and i also have another one of them i did have running the other day it charged up in the green had all but one bar drove it for approx half an hour gas motor never shut off the whole time and also when i put the new 12 volt battery in i put the pos on first and when i put the ground on the neg post i get sparks its ready 12.7 this is a 2005 prius i don't know much about it i bought it off a friends daughter she stated she took it to a dealer and they told her it need a hybird battery so i replaced 10 cells in it
  10. dale trout
    mingo jct oh
    i checked on hv voltage 222.3 and on the other side of it where the leads go to the front of the car i'm getting 80 and it slowly went to 140 volts and stoped cold the relays be stuck help please
  11. bisco
    52,863
    there's a lot more to a hybrid battery than replacing the cells. read through some rebuilding threads and start a new thread to get more attention. all the best!(y)
    Raytheeagle likes this.
  12. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Can you provide a photo/photos of the electronic section of the hv battery? We can at least tell you if it looks to be assembled correctly. You shouldn't have any voltage on the car side of the relays until you press the power button and the main relays shut and the car goes "ready".
    Do you have a code reader that can display hybrid codes?
  13. dale trout
    mingo jct oh
    the only time i have volt on the car side is when i push the start button but it starts at 80 volts and climbs up to 150 volts very slowly and stops there at 150 volts but with the star button still pushed on the othere side i get 222.3 volts and i only here the precharge relay kick in the other 2 relays don't kick in only a couple time they hve and when they did the car started and the hv charged up in the green but the gas motor would not shut down my guess is the 2 relays on the hv battery are bad i'll try to take photos but the cover is on the cell part of the battery
  14. Krisstroll
    Krisstroll New Member
    France
    Sorry if i am in the wrong discussion
    hello everybody , I m new on the forum, back in Europe (France) , and not much of people who knows something about working on a prius here, i am trying to solve a pbm :
    prius 2 ; august 2006 ; 192000 KM , used when bought , Tranny maintenance ? 12 V battery fully charged every time i try to start but used
    i had a HT battery failure, bill from toyota that i refused (2500 €), i change my self the 2 faulty elements (thanks you tube) and put back everything : 212 V on testing
    when i brought my prius 2 back home the thermic was working D & R but of course electric was not working.
    since then , and I checked and rechecked everything, the orange big security plug position (as mentioned by several personns) all the 3 connectors to the ECU, the connector to the Fan , even the polarity of the HT connectors ....
    same old song : THE READY MODE DOESN T COME ON, NO D OR R POSITION POSSIBILITY, THE THERMIC DOESN T FIRE UP , I noticed that i don't hear the Clac Clac of relays ans that the 12 V battery is drained after 1 day if stays connected. NO error CODE on ODB device
    i desinstalled one of the 2 main relay to try to test it, but i am stucked
    any ideas ? any suggestions, HEEEEEELP PLEAAASSSE
    thanks
