2007 Front Passneger Door
Discussion in 'Gen 2 Prius Main Forum' started by Dang Pham, Jul 25, 2022.
  1. Dang Pham
    Dang Pham New Member
    Lynnwood, WA
    I lost control and hit the guardrail. Planning to sell it, but should I sell it as is or replace the door and sell it? I dont have full coverage so i’d be out of my pocket. I can start the car, still drivable. the only thing wrong I see is that door and the front passenger wheel. 77,000 miles.
    Also does anyone know how much to replace the door?!
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    I can get a complete door for about $50 from Pull-a-Part. I don't know if those are in your area.
    Looks like something underneath the car may have buckled also. Directly under the door area.
  3. PriusCamper
    PriusCamper Senior Member
    13,472
    5,440
    Pacific Northwest, USA
    Yea, the picknpull .com in Lynwood, Washington gets the most wrecked Prius in the area. But they don't have any of 'em right now. I'm a couple hours south of you and could put a different door on, but I suspect there's more damage than just the door and the replacement door might require more than just hitting stuff with a hammer to make it fit. I also got a spare wheel and tire to fix it but again, there could be more damage that needs to be fixed than just that. I sure would love to have a 77K mile 2007 Prius, that's for sure.
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Agree, there's damage to the rocker panel area under the door.
    You won't be able to slap another door on it, the frame around the door is most likely distorted.
    You should probably sell it "as is".
    Dang Pham likes this.
  5. bisco
    52,889
    i would investigate the repair work cost at some body shops. doesn't have to be perfect, but you will get a lot more retail buyers if it's in decent shape. and used pri are worth a fortune right now.
    otherwise, all you'll get is bottom feeders.
    if the frame is bent, you're probably sool
  6. Dang Pham
    Lynnwood, WA
    These are other stuff I just noticed. Would you be able to tell if the frame is bent or not?!
  7. bisco
    52,889
    no, i think you need a pro. that first shot might be the plastic under belly?
  8. alftoy
    alftoy Senior Member
    1,132
    520
    Saskatchewan, Canada
    Have someone hold a straight yardstick just below the door on the rocker panel, so you can see how far the rocker panel is bent. This yardstick is next to my rocker panel on the Prius.
  9. xliderider
    8,140
    3,280
    Honolulu, HI
    That picture with the wonky dash is indicative of a bent frame, at least around the door.
