2007 hatch release has no power
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rkeith3472, May 15, 2021.
  1. rkeith3472
    rkeith3472 New Member
    Alabama
    ✔️ The battery is good
    ✔️ I checked both the 25amp and 7.5amp fuses and both are good and they are getting power
    ✔️ I checked it with the car running and off
    There is no power to the tiny harness that connects the hatch switch. I checked all 4 pins and nothing! Any ideas?
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,116
    6,974
    Texas Hill Country
    No connector between the body ecu and the switch. In most cases its the switch.
  3. Fred_H
    Fred_H Misoversimplifier
    562
    488
    28
    Germany
    If you determine that one of the wires between the body ECU and the switch harness is not conducting properly, then a likely place to look for a broken wire is inside or near the rubber bellows where the wires go through from the roof to the hatch.
  4. rjparker
    11,116
    6,974
    Texas Hill Country
