2007 Headlights
Discussion in 'Gen 2 Prius Main Forum' started by TouringSYNERGY2007, Feb 24, 2014.
  1. TouringSYNERGY2007
    TouringSYNERGY2007 Junior Member
    Virginia
    2007 Touring Prius with left high and low beams going in and out... thinking of replacing both soon.
    Should I check sensors or replace? What bulbs are you guys using? Expensive/cheap options?
    kenoarto likes this.
  2. Kurzweil
    Kurzweil Member
    109
    34
    Atlanta
    Do you have the bright white HID type lamps or halogen?
  3. TouringSYNERGY2007
    Virginia
    HID, Bright white.
  4. PriusGuy32
    1,411
    506
    Harrison Township, Michigan
  5. TouringSYNERGY2007
    Virginia
    PriusGuy32 likes this.
  6. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    I purchased replacement lamps from Amazon. Good price, work excellent.
  7. RebL
    RebL Junior Member
    63
    Massachusetts
    I have the 2009 Touring, which I believe is basically the same as the 2007. I find my headlights to be quite dim compared to my spouse's 2011 RAV4 and my son's 2004 Subaru Forester (halogen). Have you had this issue as well? I replaced the bulbs with little, if any, improvement. Do I just have a lemon?
  8. Augustus88
    Augustus88 Junior Member
    87
    29
    Birmingham, AL
    Three Touring
    Try aiming them up just a hair. Make sure they are not pointing up though. I had to do this on mine, they were aimed so low the car was nearly undriveable at night.
  9. RebL
    RebL Junior Member
    63
    Massachusetts
    Thanks, I will try that.
  10. tvpierce
    tvpierce Senior Member
    949
    879
    Maine
    2013 Prius v wagon
    I don't think you have a lemon. The HID headlights on our '08 aren't very "H". I adjusted them -- which helped some -- but still kinda lackluster. The halogens on my 4Runner are head & shoulders above the Prius.
  11. aliidreeskhan
    aliidreeskhan New Member
    Pakistan
    Can u suggest which bulbs should be used to replace as headlights are too dim.
  12. tvpierce
    949
    879
    Maine
    2013 Prius v wagon
    I don't have my '08 anymore (totaled in an accident)... are yours HID or H4 Halogen?
  13. TMR-JWAP
    TMR-JWAP Senior Member
    6,100
    5,811
    Columbia, SC
    Those are HID retainer spring clips. The Halogen clips look similar, but don't have both sides. They're missing about an inch from one side of the clip.
