2007 HID Headlight Adjustment
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by simul8r, Jan 11, 2008.
  1. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    A torxse head screw driver pushed into the open slot and engaging with the teeth on the small gear wheel makes it easy to adjust up or down at will without having to bother with a ratchet. There are two slots that can be used one vertical and one at an angle visible in the pictures. This also works for the fog lights putting the driver through a hole below the fog lights in the plastic under tray.
    John (Britprius)
  2. Thomas1973
    Thomas1973 New Member
    2007 Prius and we get routinely flashed by oncoming drivers who think we have the brights on. Passenger headlight definitely higher than driver headlight and compared to my Ford F150, the lights hardly seem to illuminate the road at all, but I get a great view of the tops of trees.
    So I used a box head ratchet wrench and it was super easy. do not know about torx head; I just got the concept just now.
  3. Thomas1973
    So happy to be able to fix this. I can see the road now! Wish I knew about this fix before we drove across country in June!
  4. Lutzbone
    Lutzbone I play the trombone
    Bridgewater, NJ (when I'm not on tour)
    John, thank you SO MUCH for this! My 2006's HIDs were pointing in different directions (vertically) and your post enabled me to finally fix them. I found the plastic adjustment nut but didn't know about the Torx trick. Bashed my knuckles for what felt like hours using a ratchet and socket on the little plastic nut and got no discernible difference. Then tried your suggestion and in less than 5 minutes had the headlights properly aimed. Brilliant!! You have saved my hands!! THANK YOU BRITPRIUS!!
  5. Lutzbone
    BTW I used a T40 Torx head.
  6. Hid hell
    Hid hell New Member
    Seattle, WA
    Who knows if you'll ever get this, but I have a question about this. It seems like it doesn't actually work. I tried turning that nut many many times, and it doesn't seem like the headlights move at all. Is there anything else you can tell me?
  7. Classic Car Guy
    Classic Car Guy Active Member
    506
    136
    Northwest, USA
    I popped in a new replacement / conversion bulb from HiD to LED on my 2007. Its running fine beside I need a little adjustment on the right side headlight pointing a little outside to the right.
    First off I didn't know a car like this has a headlight auto adjustment. I don't even know what it is?
    Anyways what is the right way to do this?
    Thanks, CCG
  8. ChapmanF
    19,038
    Didn't the gen 2 HIDs have auto-levelers, like the gen 3 factory LEDs do?
    If I found myself getting flashed a lot by oncoming traffic, I'd want to first check if that stuff was working.
  9. Classic Car Guy
    506
    136
    Northwest, USA
    I read the whole threading on the 2007 HiD adjustments. The one thing wasn't mention in the manually adjustment part beside the Up or Down motion is the Left or Right (sideways) adjustment. Can anyone follow-up if you find any?
    Thanks,
    CCG
