2007 hybrid battery
Discussion in 'Gen 2 Prius Technical Discussion' started by Chris corso, Dec 6, 2025.
  1. Chris corso
    Chris corso New Member
    Honolulu
    I have a 2007 hybrid battery which works fine and I want to install it in a 2013 Prius C1 is
    it compatible
  2. PriusCamper
    PriusCamper Senior Member
    13,472
    5,440
    Pacific Northwest, USA
    There's 28 battery modules in the 2007 and just 20 modules in the PriusC pack. So the answer is yes you can use the modules, but will need to put the modules into the PriusC pack assembly. And because there's less modules in a PriusC the car is harder on the modules so it might be a short-lived fix unless you do a charge and balance and maybe some deep cycling/reconditioning. Learn more about that part here: FAQ - Hybrid Automotive and you can build your own gear to save money: Build Hybrid Battery Maintenance Gear For Under $100 | PriusChat
    bisco, Carall and Brian1954 like this.
