2007 hybrid loses electrical power, using manual key on door, power returns
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Billygans, Oct 26, 2020.
  1. Billygans
    Billygans New Member
    boise idaho
    2007 Prius, after sitting a day or two in garage, we attempt to start vehicle, there is no power (no lights on dash or interior). If I use the manual key on the driver's door (lock, unlock) power returns and able to use the vehicle.
    the clock loses time, and I think (not verified yet) the MPG resets as if we just refueled.
    If driving around, no issues starting Prius. Only seeing issue after not using it overnight or longer.
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,565
    5,872
    Texas Hill Country
    Are you plugging the electronic key into the slot to start the car? If it won't work wirelessly, the keyfob battery could be dead. Otherwise it sounds like your 12v battery is bad and not holding charge well. It should easily hold charge for three weeks well enough to power the electronics. Take it to an auto supply and have them load test it. Finally, the hatch light may not be going off, sometimes caused by incomplete closure of the hatch.
    #2 rjparker, Oct 27, 2020
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,954
    1,905
    NJ-USA
    When this happens, open the hood and use a digital multimeter to check the voltage at the jump start post (I use the stud/nut for the strut mount close by as my ground point). If you have less than 12.4 to 12.6V then next step is to test at the battery (yes, that's tough when you can't open the hatch). If the battery is the same low voltage then it should be charged and tested. Might be a faulty battery. If voltage is higher than at the jump point then you have a bad/ loose connection somewhere.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    12 V battery going bad OR a bad main cable connection to same.
    Get the battery tested.......or if it is over 5 years old, just replace it.
