2007 key fob...dead?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dave0706, May 9, 2014.
  1. Dave0706
    Dave0706 New Member
    Hello everyone,
    My new (2007) Prius came with 2 smart keys. One works, the other I was told, needed a battery change.
    I changed the battery but it is still dead. I noticed when performing the change that the old battery had been in there for way too long and it left the battery compartment all rusty. The contacts seem good though, as they appear to be either gold plated or brass. Nonetheless, it doesn't work at all.
    Does anyone here have any ideas? It was a brand new battery so it's definately got charge.
    Thanks
    Dave
  2. Patrick Wong
    18,210
    6,517
    If the old battery leaked electrolyte into the non-working fob, then you probably need to obtain a new fob.
    Dave0706 likes this.
    52,804
    sometimes a button gets stuck and prevents operation.
    Dave Jeffries likes this.
  4. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    You should have asked the seller to replace the battery and demonstrate that it works.
    Too late now; maybe next time.
    It sounds like the corrosion is too extensive and it's shot.
    A thorough washing/cleaning with some isopropyl alcohol (rubbing alcohol) and a tooth brush followed by
    a thorough drying period before installing a new battery might help.......but the odds are not good.
    It is also possible that the "new" battery is dead too.
    Sometimes a locksmith can get and program a replacement for a LOT less than a dealer.
  5. Dave Jeffries
    Dave Jeffries Junior Member
    27
    Vancouver, WA
    10 years later and this was my issue. Of all things, the panic button was to one that was stuck.
