2007 knocking and battery not charging
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dereko, Nov 8, 2019.
  1. Dereko
    Dereko Junior Member
    32
    Missouri
    Was driving the car it started knocking pretty bad and at the same time the hybrid battery won’t charge much unless your coasting
    Oil level is correct, I changed the spark plugs to see if it would help and it did not
    any ideas?
    52,855
    no dash lights?
    how many miles on her?
  3. George W
    George W Senior Member
    939
    520
    San Antonio
    Do you use any code readers or scan tools?
  4. Dereko
    32
    Missouri
    No dash lights
    I plugged in my scan tool and nothing is coming up
  5. Dereko
    32
    Missouri
    255000 and no lights
  6. George W
    939
    520
    San Antonio
    Could the car be starved of fluids on a cold morning? Last date of maintenance?
  7. bisco
    52,855
    coolant level okay?
  8. Dereko
    32
    Missouri
    I just changed the oil 1000 miles ago, even after warm up it’s not any better
  9. Dereko
    32
    Missouri
    yes it’s good
  10. bisco
    52,855
    maybe an engine bearing
  11. Landon51
    Landon51 Member
    190
    63
    US
    mine is doing the same thing down to the charging problem.
    i have changed spark plugs re-manufactured injectors and finally (later today), coild from Amazon that have many good reviews but aren't Denzo).
    I'll also be installing an oil catch can today or tomorrow. hopefully that will fix it.
  12. George W
    939
    520
    San Antonio
    If you're installing a catch can you need to also start with clean MAS and throttle-body
  13. Landon51
    Landon51 Member
    190
    63
    US
    This seemed to do it. I'll drive it a week and make sure, but it seems to be fixed. no more shaking or missing. i had to change the big three: Sparks, injectors and coils.
  14. Landon51
    Landon51 Member
    190
    63
    US
    i cleaned my throttle body.
