2007 Multifunction Display fading.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tia Deb, Mar 13, 2017.
  1. Tia Deb
    Tia Deb New Member
    Plant City, FL
    First time posting, think this post is within the rules. IMG_0492[1].JPG IMG_0491[1].JPG I have a 2007 (gen 2). Recently the Multifunction Display has faded from the center of the screen. The light adjustment wheel is on full. The brightness and contrast setting are at maximum. The dashboard lights are fine. The touch-screen functions work if you press the right places (A/C, radio, etc.). The photos were taken at dusk, less is visible in sunlight. The 'green ghost' in the lower left is reflection of my phone. Are there 'light bulb type' parts in the MFD that can be replaced? Or is this a 'buy another MFD' issue? Not squeamish about taking it apart. It's JUST out of warranty and we replaced the hybrid battery 2 weeks ago (ourselves). Any suggestions are appreciated.
    SteveKHollywood likes this.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Looks to me a bit like what you get with polarization. Perhaps thereare 2 screens over the display and one has somehow gotten twisted. Someone with more sense than me will possible answer your question later, but that's all I can offer. (n)
    52,532
    maybe a loose connection? or just a defective screen that needs replacing.
    RCO likes this.
  4. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    RCO likes this.
  5. Patrick Wong
    18,210
    6,514
    Looks like you need to buy a replacement MFD; remove the original so that you can determine the correct part number, and look on eBay for a used unit.
    donbright likes this.
  6. SteveKHollywood
    SteveKHollywood New Member
    Hollywood, FL
    I have the EXACT same issue.. Same 2007 Prius.. And also live in Florida.. Would rather not have to buy a whole new MFD.. Any way to just change the screen? Or clean it?
    CPate2020 likes this.
  7. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  8. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  9. bisco
    52,532
    welcome!
    i don't think cleaning is gonna help, but give it a shot before buying a reman on eBay.
  10. The Other Guy
    The Other Guy New Member
    Orlando, Florida
    I
    I also have the same problem with my screen on the MFD. Did you find a solution to this? My current assumption is that this is being caused by sun damage to the screen. I also live in Florida and I noticed that the screen darkening started after my A.C. went out. I drive with my windows down a lot causing the MFD to be in direct sunlight. I know there is a polarized filter in front of the screen and I wm wondering if it can be replaced easily.
  11. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    You need back light to see the screen like a led tv. It normaly a light on the side of the screen either the light gone out or it not in place
    RCO likes this.
  12. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    If it is sun you just need a new dark tint. Filter (window tint) you can tell him dark of time by the the spot that still works a little lighter. I think you back light out on one of the side of the screen kind like dash lights but on the side
  13. HV Battery
    HV Battery New Member
    22
    Oklahoma
    it looks as if it's gotten too hot, what temperature weather do you live in? Probably best just to replace the unit for a cheap used one on eBay
  14. JBuckPrius
    JBuckPrius Junior Member
    64
    Knoxville, TN
    This is what our 2006 screen looks like...just not as dark. We spent many years in south Florida before this happened. What have you done to repair it? Is it a backlight? Or, has the screen been sun damaged? What have you done to remedy the situation?
  15. EchoAlphaMike
    EchoAlphaMike New Member
    Weeki Wachee, FL
  16. EchoAlphaMike
    Weeki Wachee, FL
    I have a 2005 with the exact same problem. I thought that it might be the digitizer screen, which controls the touch screen function, and which is the least expensive to replace, so I dismantled the MFD, and replaced it. Although it did improve the viewability of the screen it did not completely correct the problem. It appears that the main culprit is the units LED which sits behind the digitizer. I believe the best alternative is to find a good used MFD. The dismantling of the MFD to replace the digitizer is time consuming but can be done with patience. The biggest problem in removing the MFD was removal of the A/C vent covers which were so brittle with age that they all broke when being removed, regardless of how careful I was.
  17. Nickkliesen
    Nickkliesen Junior Member
    26
    Brooksville, Florida
    It seems this is a common Florida Problem I am going to change out my digitizer this weekend to see if it resolves the problem if not i will begetting a reman unit to replace the whole unit
  18. CPate2020
    CPate2020 Junior Member
    Columbia, SC
    I had the exact same issue with my 2009 MFD. The Southeast heat must’ve fried it. Bought a used one from EBay and swapped it out and it’s alive again.
