2007- Navigation reverting to default settings?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by drw, Jan 20, 2015.
  1. drw
    drw Junior Member
    31
    I have a 2007 Prius with about 150,000 miles.
    This has happened a couple of times in the past 2 months, and was wondering if anyone else has seen this:
    Our Navigation system seems to be resetting itself- this morning it happened for the second time in the past 2 months:
    Volume resets
    Search location changed
    All “previous” destinations are gone.
    Not sure if any other settings changed, but those are the 3 that are obvious- it is almost as if it reverted to some kind of default settings. The nav does work just fine, however.
    This happened about 2 months ago, and it happened again today.
    Anyone else ever seen this, and is it anything I should worry about??? No other problems other than that………
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Check your 12V battery. The resets are typical of low 12V battery voltages.
    Salvage09 likes this.
  3. drw
    drw Junior Member
    31
    That was my thought as well- I did the test battery procedure and all the levels were in the normal range, so I am just wondering if there could be another reason......
  4. jdcollins5
    5,131
    1,346
    Wilmington, NC
    What are you calling a normal range? Give us your voltage readings for each of the tests in the procedure.
    If your 12V battery is truly OK then I would have to suspect a 12V connection to your Nav unit.
  5. drw
    drw Junior Member
    31
    12.5 first reading
    12.1 after pressing power
    14.1 full power
  6. jdcollins5
    5,131
    1,346
    Wilmington, NC
    What is the voltage after pressing power and with headlights on ?
    Your readings are actually marginal. The first reading should be closer to 13V.
    How long have you had this battery ?
  7. drw
    drw Junior Member
    31
    I have been checking the battery the past few days:
    12.3-12.5 first reading
    12.1 second reading
    14.1 full power with lights on
    Have had the battery a little over 3 years.
  8. jdcollins5
    5,131
    1,346
    Wilmington, NC
    When the car is in Ready mode the battery is being charged by the DC/DC Converter from the HV Battery. So lights on with the car ready does not tell you anything.
    What is the battery voltage with the headlights on without the car being in Ready mode?
  9. drw
    drw Junior Member
    31
    I followed the instructions found on here in posts about getting into the check mode (push power button once then following steps to get to maintenance mode)
    Unload- 12.5 (lights off) 11.9 (with lights on)
    Unless I am missing something, aren't those pretty normal numbers? They are according to the articles I have been reading, but maybe I am mistaken
  10. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    No, those are not normal readings, but marginal at best.
    How long will it hold 11.9 V with the lights on before dropping to 11.8, 11.7, 11.6, etc.
    Also, if this was me, I'd consider that your battery is fully discharged so I'd be charging this battery up to full with a good quality smart charger that had an AGM setting. Once charged, check the sitting voltage after the surface charge has dissipated--it should read a voltage of 12.8-13.2 V after sitting for 2-4 hours after removing the charger. I would then repeat the test of the three voltages paying closer attention to how long the battery can hold a constant voltage under load (headlights on is sufficient), and also noting the time taken to drop each 0.1 V under load.
    If you care to do that and report back the results, then we can more or less tell you whether your battery is passed it's "use by". But my opinion even now is that it is and it needs to be replaced. Having said that, charging in the short term may buy you some time so you can select a replacement battery.
    hope this helps.
