2007 New Toyota Hybrid Battery - Self Install?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gatorglenn, Jun 27, 2016.
  1. JC91006
    16,915
    8,633
    It's slightly more complicated, but that's what attaches it together....3 nuts. Follow the wires to disconnect from your original pack.....then reverse order, reattach to new pack. It's really pretty simple. Just don't get electrocuted
    Merkey likes this.
  2. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    Oh I thought the special orange paint Dorman uses on the battery cover protected it against future failures.
    If you to pay for someone else to put it in, then better off going with new battery for long-term.
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    It's more than 3 nuts, and there is definitely ways to do it wrong or make a mistake. I've watched guys make spark because they were working to fast or not paying attention. Torquing the bolts correctly is an easy error. You are working with high voltage that powers the car and a loose connection or over torqued connection are equally problematic.
    I had one last month from a dealer that did not have things torqued and it came loose taking out other electronics.
    Heck, some people don't even bother cleaning the fan (Not cleaning fan voids the warranty) when doing replacements for the "drop in" Dorman option. So it is easy to imagine people skipping steps on when doing a more-involved OEM replacement.
    Go slow. Work methodically. No reason to rush.
    edit: clarified about cleaning fan
    #23 ericbecky, Jul 1, 2016
    cwerdna and bisco like this.
  4. Mendel Leisk
    42,165
    Do the replacement batteries tend to come with an instruction sheet with torque values? Or is the onus on the installer to dig it up from the Repair Manual?
    Also, I assume you mean not cleaning the fan voids the warranty?
  5. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    The batteries do not come with an instruction sheet. Since they are mainly done by dealers, and the techs have to go through training, it is assumed that you have access to the Repair Manual.
    Installer must clean the fan or the warranty is voided.
    I edited my post for clarification.
  6. gatorglenn
    gatorglenn Member
    138
    45
    Atlanta
    Just a quick update. I was able to buy a new Toyota battery from a dealer and installed it myself. I only had one dumb mistake which delayed finishing the install a little bit.
    All in all I am very happy with the battery. I will post some details and a couple of pictures in a new thread.
    Thanks,
    Glenn
    JasonATX and bisco like this.
  7. bisco
    52,674
    well done, all the best!(y)
  8. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Please tell my you took the cover off and got the module date code numbers.
  9. bisco
    52,674
  10. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    The cover must be removed to do the parts swapping between the old and new HV batteries (with the G9510-47031 battery in the Gen2).
    Toyota has started selling remanufactured batteries with brand new modules that are drop in units. Those batteries have the -84 suffix that is used for all remanufactured components - like brake calipers, master cylinders, etc. Don't know when those will be available nationwide. They have been available in limited quantities on the left coast.
  11. bisco
    52,674
    is that a bad think?
  12. jadziasman
    1,355
    488
    District 6
    Is what a bad think?
  13. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    I assume a dealer should make it clear it if is new or remanufactured.
  14. bisco
    52,674
    the 84. i'm trying to figure out why, when you buy a new battery, you need to remove the cover, and check the module date code numbers.
  15. jadziasman
    1,355
    488
    District 6
    This is the rare battery I referred to. This one you can install just like a Dorman. No parts swapping required.
    Maybe this is what fotomoto thought that gatorglenn bought. If so, I hope glenn will clue us in.
    Module date code numbers are peace of mind that you received fresh new modules. So, it would
    be essential to verify that the modules were indeed brand new when you bought the battery above.
    Someone on Priuschat supposedly bought the -84 battery but never followed up with more info.
    bisco and fotomoto like this.
  16. fotomoto
    5,639
    3,815
    So. Texas
    I'd actually prefer to see module date code numbers. IOW, how new is new?
  17. bisco
    52,674
    never heard of this before. what the price difference between new and remanufactured?
  18. jadziasman
    1,355
    488
    District 6
    Supposedly less for the -84 than for the standard new one from what I vaguely recall the Priuschatter mentioning.
    There is a mystery what's actually inside the case - brand new modules or old ones. Toyota might have gotten
    into remanufacturing late in the game.
    I cannot find any details on my Google searches for the -84 battery. So does this battery really exist?
    Could be just an elaborate prank.
    2006 Prius with 179,000 and battery just died | Page 3 | PriusChat
    #38 jadziasman, Jul 5, 2016
  19. bisco
    52,674
    very confusing. this is the first i've heard of it.
  20. JC91006
    16,915
    8,633
    So far it seems both examples of this 84 code battery has come out of San Diego dealership in California. It's not a joke, it's an actual part they are selling to customers for only a couple hundred less than New
    I posted the picture of the black case with sticker, someone bought one that wasn't black. I found that strange
