2007 No AC assistance - B1421
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bgustafson, Jul 6, 2018.
  1. Bgustafson
    Bgustafson Active Member
    259
    222
    Chicago
    Hi friends -
    I'm trying to solve my parent's '07 AC issue. Basically it blows warm / hot air. Could be a number of things, so I finally got Techstream up and running, and here's my first attempt to pull some data. What are my next steps to investigate? I've never messed with the AC before so be patient with me. (y)
    They're at 230k and still running on the original HV battery. :whistle:
    Thanks!
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Click on the snowflake icons for more detail;).
    The B1421 code just means that you prius was probably in the shade r a garage as the solar sensor didn’t sense the sun.
    Freeze frame data for the hv battery looks good though (y).
    SFO, ITBland and Bgustafson like this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Does it NEVER blow cold?
    I have seen AC that sometimes works and doesn't, that ended up being the first signs of the inverter cooling pump failing.
    Has the refrigerant charge level sightglass been checked?
    Is it fully plugged in at the inverter? The plug is located at the front passenger side of the inverter.
    SFO, ITBland and Raytheeagle like this.
  4. ITBland
    ITBland Active Member
    433
    278
    New Orleans, La area, US
    SFO likes this.
  5. Bgustafson
    259
    222
    Chicago
    Here's a shot of each snowflake. I'll check the sight glass.
  6. Bgustafson
    259
    222
    Chicago
    Just to follow up on this topic for anyone who may be searching in the future ... it ended up being the compressor. $$$. My parents had Toyota do the work. I didn't want to fiddle with this one.
    ITBland and SFO like this.
