2007 no ready light b2287 b2289
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rick33, Apr 4, 2017.
  1. rick33
    rick33 New Member
    hannibal
    I
    I just purchased a gen 2 prius, It acts just like a dead 12volt battery except the interior lights and headlights function correctly. The only thing lit up on the dash is a door ajar light. I pulled 2 codes, b2287 LIN communication master and b2289 key collation waiting time over. My service info says the LIN1 wire betwwen the ID code box{possibly the transponder key ecu} and the power source control ecu may be open or shorted. I have pulled the dash cap and need to know where to find these 2 ecu's . Any help out there?
    52,878
    welcome!
    is it worth checking the 12v?
  3. strawbrad
    953
    1,007
    You might have a blown fuse for the invertor coolant pump. Check the 15A AM2 fuse (located on Unit B in the main relay/fuse box) .
    Brad
  4. rick33
    rick33 New Member
    hannibal
    I
    All fuses are good. I have figured out the power source control ecu will not power up the 3 relays IG1 IG2 and accy. I put power to them and it starts/ready up. I have drove it about a week when it did it again. I need to know if anyone knows what needs to happen for the power source control ecu to come online?
  5. Sauna
    Sauna New Member
    Finland
    Did you find the solution? I'm having the very same problem here
  6. 1992
    1992 Junior Member
    owensville
    did you ever fix you problem
  7. abcsoup53
    abcsoup53 Junior Member
    45
    Did you fix the issue? What worked?
