2007 overheated and no heat inside
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriusDadNoob, Jan 9, 2023.
  1. PriusDadNoob
    PriusDadNoob Junior Member
    72
    I just replaced the inverter pump and ICE thermostat and coolant in both systems. Test drove the car and I got the “overheated triangle”
    Both the upper and lower radiator hoses feel cold to the touch and there appears to be no heat in the car even after 10 min driving.
    What have I done wrong? What could this be?
    Also the new inverter pump seems louder by a lot than the original. I bought a genuine Toyota:-(
  2. PriusDadNoob
    72
    The coolant level in the ICE overflow looks ok.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    Both problems could be air trapped in both systems. What did you do to fill and bleed them? Why did you replace the thermostat?
    PriusDadNoob likes this.
  4. PriusCamper
    PriusCamper Senior Member
    13,449
    5,430
    Pacific Northwest, USA
    Sounds like a bad thermostat...
  5. mr_guy_mann
    4,113
    2,011
    NJ-USA
    I bleed the inverter by connecting a clear hose from the bleeder screw (in front of the inverter) to the opening in the reservoir - clamp the end in place because it will spit out. Open the screw and switch ignition ON or READY.
    Coolant (and air bubbles) will flow through the hose. Top up coolant as needed- it took me about 5 minutes before all air was gone (the pump got much quieter).
    Engine- I'll assume that the new thermostat was installed "correct side out". Follow the procedure in the service manual to bleed. (I use "vacuum fill" tool, so don't have any tips for DIY).
    #5 mr_guy_mann, Jan 9, 2023
  6. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    The ICE overflow (opaque white plastic reservoir behind the radiator) generally doesn't function as designed, always check the radiator first.
  7. PriusDadNoob
    72
    I replaced the thermostat just as a matter of maintenance. I'm regretting that now! I figured at 222,000 it should be done. I could not get the lower radiator hose off the thermostat housing very easily (finally did get it off!) but I put a normal hose clamp in it's place. I just could not get that spring style one back on :-(
    I bled the inverter cooling side with the little 10 MM bolt/bleeder/nipple in front of the inverter itself. Just ran the car in accessory mode (two button presses with no foot on the brake) and let it run coolant up the 1/4 in tube that was running to the inverter expansion tank (clear one by the inverter)
    The ICE system was harder. I initially refilled via the radiator, letting it bubble, slowing adding coolant, then filled the expansion tank/overflow, then ran the engine and added coolant as it disappeared from site in the radator. Strange thing, it kept coming back up the funnel so I think I did not get enough coolant in the radiator. I took out 6 quarts but only managed to get 4 back in.
    After I got the overheated sign/triangle tonight after 3 miles of driving I stopped to let it cool, then checked the radiator and I could not see coolant so I added it to the radiator. It burped air and let me add another 1-2 quarts. I think I'm missing something with the ICE bleeding process. I did try to connect the bleeder on the driver's side of the radiator using a 1/4 in hose to the radiator but it never seemed to send a steady flow of coolant. Perhaps the hose is too large as it did not seem to fit on as snugly as the nipple type inverter bleeder.
    Any help is appreciated as I need to get this car back on the road for my daughter! Thanks!
  8. Tombukt2
    Tombukt2 Senior Member
    13,848
    2,515
    Durham NC
    In willmore Kentucky you may need longer than 10 minutes to get any kind of serious heating going on maybe run at 5 minutes and then pull back into your driveway and slowly undo just the ice coolant stuff while it's just beginning to supposedly heat up that's when you want to be squeezing and moving your hoses while engine is beginning to heat things a little bit milk that bottom hose like you mean it You also want to check the top hose and that hose that runs from the coolant valve and makes the loop all of that needs to be happening You're obviously not overheating because you're still grabbing hoses and things are happening If you're feeling all around the engine at all of these hoses and nothing's warm more than likely your red triangle may have nothing to do with overheating that is possible sometimes when it's cold it will take a few minutes You've also got some preheating business going on trying to get your heat ready if that's not happening then there's probably a coolant moving and level problem.
  9. PriusDadNoob
    72
    Do you think I should pull that new thermostat and put in a genuine Toyota part or at least one that matches the original equipment better (with the jiggle pin on the metal outer ring?)
  10. Tombukt2
    13,848
    2,515
    Durham NC
    I don't know if I would change it for all of that what I might have done or might do if I really thought this was something is take the thermostat back out put it in hot water use Mama's candy thermometer and make sure that it's starting to open or whatever the specs are around 180° something like that You can actually see the thermostat start to open and slowly open more and more is the temperature increases and then make sure that the thermostat is inserted the correct way if you put it in upside down you've got a problem If you don't like the fact that there's no jiggle pin use a small drill bit and make one
  11. Tombukt2
    13,848
    2,515
    Durham NC
    Usually today even crappy stats will function. I'm assuming a stant or robertshaw branded stat maybe even balanced . Spring goes towards pump
  12. JC91006
    16,936
    8,647
    If you took out 6 quarts of coolant and only put back 4 quarts, that means you don't have enough coolant. Bleed the system and make sure you are in maintenance mode while you let the car run. Monitor the level in the radiator (not the reservoir)
  13. Tombukt2
    13,848
    2,515
    Durham NC
    Yes but I think once that coolant starts to get hot enough the level will rise quite a bit not two quarts worth granted. But he did say he was able to get another one point some odd quarts back in the vehicle. The next morning or something?
  14. PriusDadNoob
    72
    Yep I did get the spring the right direction!
  15. PriusDadNoob
    72
    Yes I was able to add in another 1.5 quarts later on that evening. I've ordered the Lisle funnel and will do the final bit of coolant with that, using the bleed valve with hose run over to the radiator fill area (into Lisle funnel I guess)
    I hope it was just a bleeding/filling issue. I'll report back in a few days once I get the funnel. Thanks everyone.
    Also, I posted in another thread so sorry for the double post, but when I got the car my "thermos"/coolant hot storage tank lower hose was crimped off with a vice grip. Do you think that may have been to prevent a problem with the cooling system? I have unclamped it now so coolant can flow. I'm not sure what would happen if you closed off that lower "thermos" hose... other than the pump not being happy!
    Thanks again, you guys are amazing. Best forum on the planet for community and people helping people with Prii!
  16. Tombukt2
    13,848
    2,515
    Durham NC
    That some kind of coolant storage tank It stores hot coolant for whatever reason The Prius has a lot of nonsense going on with coolant everywhere It might behoove you to have a basic diagram of the radiator and the inverter cooling system The inverter cooling system will bleed itself whether you stick hoses from the bleed zerk fitting to the tank and watch it bubble or if you just fill it up with the car on and the pump running it will circulate the coolant all by itself and bleed itself out Why because it's an electric pump It will keep pumping and pumping and pumping until nothing but coolant is recirculating around that loop You can see that with the top off of the reservoir watching that coolant flow You can start watching this from a complete empty system all hoses connected start pouring the coolant in slowly as soon as the coolant hits the pump and the coolant system is almost full you will hear the air farting in the reservoir and coming up out of the top of the reservoir that you have uncovered and vanishing and then there'll be no more bubbles because it's all well coolant or pink stuff. You can't do this in the engine cooling radiator system because you have no electric pump. In the generation 3 you have an electric water pump which you can start with the text software which is essentially the same as squeezing and milking the hoses when you're doing this you want to be doing this pretty violently like you're pissed off at the hose I have not had any trouble with my generation twos cooling system bleeding ever course I own motorcycles and powersports equipment made by Italian manufacturers that people will tell you are literally impossible to bleed I do it in the first 2 minutes and I spend all my time riding these vehicles not working on them. I don't know about any special funnels or any of that kind of stuff I see people that have pumps and things to do all this I have never ever in my life had to do any of that and I've had to change coolant and hundreds of vehicles of all kinds doesn't make me special far from it just haven't had to go through well a lot of the stuff being discussed in many of these posts with these vehicles.
  17. PriusCamper
    13,449
    5,430
    Once you exhaust easier diagnostic options about that thermostat's functioning that'd be the way to go... And keep in mind ten minutes of driving in winter might not be long enough to get the coolant up to normal operating temp.
    As for air in the system, simply adding coolant via the radiator cap every time the system is cold usually resolves that concern. A bad thermostat or air in the system will have near the same symptoms...
    PriusDadNoob and vvillovv like this.
  18. PriusDadNoob
    72
    Thanks @PriusCamper I plan to get that Lisle funnel that people rave about and make sure all the air is out of the system. If that does not resolve things I will put a genuine Toyota thermostat in there.
    Thanks everyone, Again I will report back here once I've got the funnel. Probably in a few days.
    PriusCamper likes this.
