2007 P0A93
Discussion in 'Gen 2 Prius Main Forum' started by KitsuneVoss, Aug 15, 2025.
  1. KitsuneVoss
    KitsuneVoss Member
    373
    55
    Virginia
    I am getting hit by disaster after disaster but might have a solution
    My 2009 had it coolant pump replaced about 40K miles ago.
    I believe the inverter coolant pump is part of the inverter?
    Can I just simply swap inverters?
    Edit: Never mind, I found that the inverter water pump is actually just under the driver's side headlight. I think I can do the same thing however.
    #1 KitsuneVoss, Aug 15, 2025
  2. KitsuneVoss
    KitsuneVoss Member
    373
    55
    Virginia
    Replaced the pump with the one from the 2009. I checked before I changed them out and there was no fluid movement in the fluid reservoir before I replaced it and saw rippling with the replacement
    In my 2009, I had it changed out by Toyota, thinking it would be too hard for me to do. The whole job likely took under an hour between both cars. Definitely less than two hours. I really feel ripped off considering that they charged me something like $500.
    Drove the car back and forth to DAV, 15 minute trip each way and about 8 miles each way. Hope that was at least a half decent test.
    Is Code P00A93 95% of the time "Replace Pump?" I know if can be due to air bubble, fuse to pump, and a few other things but are they pretty rare?
  3. Tombukt2
    Tombukt2 Senior Member
    13,517
    2,433
    Durham NC
    20 min change leaving original pump bracket left in place. new pump on old bracket. Cooloant in air gone code should be gone.
    Meter guy likes this.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,098
    2,001
    NJ-USA
    It could also be something like leaves and dirt blocking the bottom 1/4 of the radiator. The code just indicates that the inverter got "too warm", so anything that affects the cooling SYSTEM can be a concern.
    Yes, most times it is the pump. I have read accounts here of some people having problems with some aftermarket pumps that would occasionally just "not pump". Then work fine next drive.
  5. KitsuneVoss
    KitsuneVoss Member
    373
    55
    Virginia
    If I have to buy a new pump, it will have to be an aftermarket due to current finances but currently using a used one from my wrecked car. Should be a revised model of the pump.
  6. Meter guy
    Meter guy Junior Member
    53
    I've replaced my coolant pump multiple times in 10 years. there are pumps on amazon new for 25$ can't help but wonder if they are the same pumps that places like advance auto sell for 200$
    my factory pump lasted to 133K (2009-2019)
    the Toyota OEM dealer replacement at 133K only lasted 79K and ran for 3247 hours
    that was replaced with a used one that got me 56k and it ran for 2057 hours.
    the current replacement from nov 2024 is an advance auto lifetime warranty model
    its run for 762 hours and 18K
    and as another mentioned, don't bother replacing the bracket, just remove the 3 bolts that hold the pump to the bracket. it will save you so much time
    #6 Meter guy, Aug 17, 2025
  7. Tombukt2
    13,517
    2,433
    Durham NC
    There are 12 volt low and medium flow coolant pumps available from major mfgrs smaller easier to fit w 5/8 barbs in proper orientation
  8. KitsuneVoss
    KitsuneVoss Member
    373
    55
    Virginia
    I am tempted to buy an Amazon one to put on my wrecked car just for now
    Eventually it will be donating its engine if I can ever get a snapped bolt off.
    Also, I am a big believer in the concept "If you hear hoof beats, think horses, not zebras." It is a medical concept but works for other things as well. Why I often ask in these threads what the most likely issue is.
  9. Tombukt2
    13,517
    2,433
    Durham NC
    In my generation too I can drive without it in 100° weather I'm usually not on hi way running svc calls did gor a year not an issue at all
  10. KitsuneVoss
    KitsuneVoss Member
    373
    55
    Virginia
    I was worried about exactly that. I was about 25 miles from home and had a feeling that it was the inverter cooling system. It was also about 85 to 90 degrees. If I tried to call AAA, I suspect I would have waited 4 or 5 hours to get her towed home because in a pretty rural. I once waited something like 8 hours for a tow. Also had my dog in the car where we were going hiking. Instead I took the car home and was able to replace the pump the same day, within two hours at worst. Glad to know that your post seems to indicate that I can likely get the car home if it is that code.
  11. Tombukt2
    13,517
    2,433
    Durham NC
    You shall more than likely have no trouble getting the car home . At all . Maybe if you blow a tire and you don't have the mini spare
