2007 Prius - 1.5L Engine - Spun Rod
Discussion in 'Gen 2 Prius Main Forum' started by oldstock79, Oct 6, 2024.
  1. oldstock79
    oldstock79 New Member
    US
    Need some specific advice-
    After spending what seems like a lot of time and work fixing a Gen2 Water Pump(INV), O2 sensors etc- now the motor has spun a rod- It has 145000 miles
    I think when I changed the valve cover gasket which was leaking bad- I might have somehow put some debris into the motor that eventually caused a clogged oil line and resulted in the issue.-
    So- with this many miles - is it worth swapping a new/rebuilt 1.5L in? Looks like a lot of work from a labor perspective but overall do these hold value enough to continue to invest time and money in? or is it time to say bye -bye?
    52,901
    that's low miles for a gen 2, but keep in mind you might need a battery soon, and possibly a brake actuator
  3. PriusCamper
    PriusCamper Senior Member
    13,476
    5,441
    Pacific Northwest, USA
    Gen2 Engine swaps are pretty easy compared to most engines. I'd encourage you to go for it so you can keep driving the best car made 2004-2009.
  4. oldstock79
    US
    Thanks for the replies! Prius Camper and Bisco- I will think on this for a little while. Engine swap video is cool!
  5. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    It is a common mistake to think of cars as an investment. They are not. They are also not an asset but a liability. A car depreciates 20% of its value in the first year and up to 50% by year three. Cars should only bought and paid for in full – financing a car is a pathway to poverty so only buy what you can afford.
    So now that's out of the way, how much will it cost to exchange your current car for a similar or better car, and do you have the funds to finance that outright? Compare that with how much it will cost to get your car roadworthy – all else being equal.
